Hot Spotting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-28-2012, 01:25 PM - Thread Starter
JoeBoy73's Avatar
Liked: 26
Just got my 150" 16:9 screen (1.1 gain) up and I'm noticing some hot spotting in the dead center of the screen:) My projector is about 19ft back and it's only really noticable during bright scenes. Any thoughts on how I can correct it? Or is it even possible to fix it?
JoeBoy73 is offline
post #2 of 3 Old 11-28-2012, 03:36 PM
airscapes's Avatar
Quoted: 334 Post(s)
Liked: 277
um.. what projector, where is it mounted, what screen brand and fabric..
If your projector has an eco mode, try it, if you have not used a calibration disk to properly set contrast and brightness do so, try a different projector mode, if you are using lens shift try moving your projector up higher or down lower and readjust the shift. Buy a different screen with a fabric that has been reviewed and is known not to have any hot spot issues..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 3 Old 11-29-2012, 07:49 AM - Thread Starter
JoeBoy73's Avatar
Liked: 26
Sorry about that...I thought the problem was more general. I have a Viewsonic Pro8200 and it has no lens shift (part of the problem?) It's celing mounted as far back in the room I can go and I'm projecting on to a Elite Cinewhite 1.1 gain screen. After adjusting some settings, I was to improve it a little bit.
JoeBoy73 is offline
Reply Screens
