recommendation: looking for gray screen with a of gain 1.4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-09-2012, 12:53 PM - Thread Starter
mprother's Avatar
hi I am looking for a gray screen for my living room but I have some ambient light. I've looked into the SI Black Diamond however it is a little pricey. What other screens can you recommend that are cheaper but with similar performance to the SI screen.
Mike
mprother is offline
post #2 of 4 Old 12-10-2012, 06:39 PM - Thread Starter
mprother's Avatar
here is a little more info about the room:
- The room dimensions are the following: 22'L x 13' W with 10' cleanings, viewing position from the couch is 20' to the screen
Projectors I am considering:
- Sony vpl-hw50es,
- Espon 5020UBe,
- Panasonic PT-AE8000.
The thing I am most concerned about is light control and contrast, however we don't do a lot of TV watching during the day since we have cut the cable service.
Suggestions would great..
-Mike
mprother is offline
post #3 of 4 Old 12-10-2012, 06:48 PM
BobL's Avatar
Liked: 56
Stewart Firehawk
Da-lite High Contrast Cinema Vision
Vutec Silverstar
DNP Supernova
BobL is offline
post #4 of 4 Old 12-13-2012, 09:36 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3094 Post(s)
Liked: 3022
Stewart Firehawk
I own both of these screens ( I consider the HCCV the " poor mans Firehawk " ). They both work well to maximize contrast, and minimize the image washing out with some light in the room. Or, you could possibly use a High Power screen. 20' is a long way from a reasonable sized screen ( I sit 12' from a 120" diagonal screen, just FYI ).
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
Reply Screens
