Possible to use a "pull down" screen as a "pull up" screen ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-09-2012, 08:29 PM - Thread Starter
lordramz's Avatar
Can I mount it to the back of a piece of furniture, upside down, and just pull the screen up ? Or will the lack of gravity create too many waves? What if I fabricated more hooks across the bar to even it out?
lordramz is offline
post #2 of 4 Old 12-10-2012, 10:09 AM
old corps's Avatar
Quoted: 144 Post(s)
Liked: 83
Ed
old corps is offline
post #3 of 4 Old 12-11-2012, 10:48 AM - Thread Starter
lordramz's Avatar
so that won't work ? can you please tell me why ?
lordramz is offline
post #4 of 4 Old 12-11-2012, 11:32 AM
dougri's Avatar
Liked: 39
The trick would be getting the screen flat... the weighted bar provides even tension across the width of the screen... that may be difficult to replicate without a fairly complicated attachment to whatever you attach it to (I'd expect single point attachment to have waves due to flex in the bar). Also, not clear if the spring/retension mechanism will operate effectively to provide the anchor at the bottom... and if not, the attachment to the screen at the bar may not support the weight of the case (which is much greater than the weight of the bar). Only way to find out is to try it, but I'd expect there is a good chance you'd be wasting your money.
dougri is offline
Reply Screens
taboola here
