Best screen for under 1000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-17-2012, 04:17 PM - Thread Starter
karkid's Avatar
Just finished painting the basement Flat Black, Looking to upgrade my Blackout cloth screen. Currently using a JVC HD250 Projector any recommendations? i'm fairly new to screen stuff
karkid is offline
post #2 of 3 Old 12-17-2012, 07:26 PM
henrich3's Avatar
Quoted: 585 Post(s)
Liked: 502
Peruse the screen threads to find a few good prospects, then contact the manufacturers for samples. Hanging a few samples on the blackout cloth will make it easier to decide.
My favorite is Da-Lite's High Power -
http://www.avsforum.com/t/773065/high-power-a-review-part-1/0_40
http://www.avsforum.com/t/1213577/da-lite-hi-power-new-or-old-what-did-you-get/0_40
Mike Garrett (Mike@avscience.com) helped with my screen purchase & installation questions. I recommend that you contact him when you're ready to select a specific model.
henrich3 is online now
post #3 of 3 Old 01-03-2013, 07:30 AM
BYRD82's Avatar
Thanks for the info as I am also looking at more cost affordable screens.
BYRD82 is offline
Reply Screens
