Height of speakers behind AT screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-18-2012, 05:55 PM - Thread Starter
jstoddard's Avatar
Quick question - cutting walls tomorrow to install 3 front speakers behind a 2.35 acoustically transparent screen.
Is it better to:
(a) center speakers vertically behind the screen? or
(b) place speakers behind the screen with the tweeters at ear level (this would put the speakers several inches below the vertical center of the screen.
My guess is (b), but could see an argument for (a)
Any thoughts? Thanks in advance.
Jeff
jstoddard is offline
post #2 of 3 Old 12-20-2012, 08:31 PM
chriscmore's Avatar
Quoted: 166 Post(s)
Liked: 186
It depends on your speaker's overal and tweeter height and the mounting height of your screen. If you are elevating your screen a little high, usually due to making room for other rows, then I'd mount the speakers as low as possible within the screen area. If it helps, you can mount the speaker upside-down if that helps get the tweeter lower or if it's a tall channel. If you're not mounting your screen that high then b) and a) are closer together and less of an issue. One of the many advantages of an AT screen is that you can mount the speakers wherever they perform best, independent of the screen = acoustic best practice. But if you need a guideline, I'd say if eyeline is about 40" from the floor, the tweeters should be from maybe 36" to 56" up.
Cheers,
Chris
Seymour AV
515-268-3369
Seymour-Screen Excellence
515-450-5694
chriscmore is offline
post #3 of 3 Old 01-04-2013, 12:58 PM - Thread Starter
jstoddard's Avatar
Thanks Chris - just got around to mounting the speakers and did as you suggested. Ear level which puts them below the vertical center of the screen. Thanks for your help.
Jeff
Reply Screens
