How do screens differ in general from say VApex, Elite, Monoprice, Carada, Elite to a Stewart Screen. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-22-2012, 07:42 AM - Thread Starter
mohmony's Avatar
Iam helping out a find out together a media room in his New Home with a dedicated Media Room (Light is not an issue here)..
I personally have a Carada Screen in my media room and quiet pleased with it and no issues since the last 4 years.
Iam looking at a Fixed Frame - 16:9 setup for the new media room.
However, As far as screen choices go.. How do screens differ in general from say VApex, Elite, Monoprice, Carada, Elite to a Stewart Screen.
mohmony is offline
post #2 of 2 Old 12-22-2012, 08:09 AM
airscapes's Avatar
Quoted: 371 Post(s)
Liked: 297
Same way a Suzuki, Kia, Honda, Lexus , Rolls Royce differ.. they are all cars and will get you there, but some are more expensive, have more options, perform better and are built better. a $300 screen is just that a white piece of vinyl stretched over a flimsy frame. The fabric is thin, and possibly not color neutral but if you only have $300 it will fit the bill
A $3000 screen is going to have a solid, well built, easy to assemble frame, with a large selection of fabric choices to fit the needs of the installation.
If you are happy with your screen, and the new room is similar in color, with the same size screen you have, why look at something unknown? If it is a good product buy it again!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Reply Screens
