Is there a trick to make a screen edge flat? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-23-2012, 12:20 PM - Thread Starter
pitbull30's Avatar
I just got a new 100" manual pull down screen. The white area of the screen is perfectly flat but the black edges are slightly curled in. Is this just a new screen flaw and i just need to wait for it to break in and relax a bit? If not is there something i can do to get the edges flat?
pitbull30 is offline
post #2 of 4 Old 12-23-2012, 01:27 PM
airscapes's Avatar
Quoted: 390 Post(s)
Liked: 307
Buy a much more expensive screen.. Sorry this is normal on low end pull down screens. If your screen ares is flat with no waves you are good to go.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 4 Old 12-24-2012, 04:12 PM
LeeC22's Avatar
How much qualifies as "much more expensive"? I paid £700 on a Draper electric screen, and didn't get flat edges, and according to Draper, it's the material, and all of the same material they have in the factory, has the same problem. My £100 Sapphire manual screen (that the Draper replaced) had nowhere near as much edge curl.
So what is the price that guarantees you get flat edges, without going for tab-tensioned?
LeeC22 is offline
post #4 of 4 Old 12-24-2012, 08:16 PM
airscapes's Avatar
Quoted: 390 Post(s)
Liked: 307
Sounds like you answered your own question.
So the edge don't effect the image, you probably can't see the curled edges with the lights off and when the projector goes off, the screen retract hiding the edges and screen. Other manufactures may have different fabrics that don't do this as much but even my tiny Dalite HP 2.8 portable has some curl to the edges. And that fabric is very thick and heavy not to mention SMALL! So if it was 110" I would think there would be some curl. If the Draper is a very thin material, I can see how it would curl with the weight of the bar.
Sorry it's not working out for you as you had expected, try and have a Merry Christmas anyway!
Doug
Reply Screens
