DNP 08-85, BD 1.4 or BD 0.8 for light controlled bat cave - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-28-2012, 04:05 AM - Thread Starter
sanderdvd's Avatar
Quoted: 163 Post(s)
Liked: 30
I just bought the JVC RS-56 and I want to achieve the best possible black level. At the moment I own a standard 1.0gain fixed frame screen 92'' horizontal. I want to have decent contrast and 'ultimate black levels'. Should I go for the DNP 08-85, BD 1.4 or BD0.8? I don t want hotspotting problems. My projector lens is almost perfect centered aimed at the middle of my screen, both vertical and horizontal.
Also watching 3D content from time to time with the active shutter glasses that came with the RS-56.
My room is a complete light controlled bat cave with EVERYTHING painted inky dark.
sanderdvd is offline
post #2 of 5 Old 12-28-2012, 11:09 AM
Kev1000000's Avatar
In a bat cave such as yours, I would either go with a gray screen, 1.0 unity gain white screen, or if you want the 3D to pop, go with a DaLite HIgh Power 2.8 gain.
The DNP nor BD were designed for a bat cave, and will introduce image problems that you don't need to introduce with your ideal setup of a pitch black room.
My Home Theater
Screen: DNP Supernova BLADE (08-85)
Projector: Espon 8350
Receiver: Yamaha RX-671
Speakers: DefTech 8060-ST
Kev1000000 is offline
post #3 of 5 Old 12-28-2012, 01:55 PM
7channelfreak's Avatar
Quoted: 286 Post(s)
Liked: 190
What about a room with only side sconces on during tv/sports?
7channelfreak is online now
post #4 of 5 Old 12-28-2012, 02:49 PM
Kev1000000's Avatar
With side lighting, BD is your best choice, although the DNP will do ok here as well. DNP has better control over image problems such as hotspotting, viewing angles, sparkles and so on, but the BD handles side lighting better.
My Home Theater
post #5 of 5 Old 12-28-2012, 06:59 PM
Quoted: 286 Post(s)
Liked: 190
Thank you! I need to go see if the sparkles is going to drive me nuts. That's the only complaint I hear about BD.
Reply Screens
