Help! 8.5" Celing, 11 ft from screen, 13 ft width room. What screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-03-2013, 08:32 AM - Thread Starter
mkedda's Avatar
Hello. I have a Mits HC5000 projector with a 92" screen. I want to upgrade to 106 or 110". The projector is at 11 ft from the screen and is mounted to the ceiling. The room is a dedicated theater room and light is completely controllable. Dimensions are roughly 9', 14' by 24' long.
What are some screen choice options?
Do I need a super expensive screen since light is very controlable?
Screen Innovations Black Diamond? Da-Lite Cinema Vision?
Thanks for your help?
mkedda is offline
post #2 of 5 Old 01-04-2013, 06:21 AM
roxiedog13's Avatar
Quoted: 1275 Post(s)
Liked: 539
Will be watching this thread as I have the exact situation and I'm going in the same direction. My room is the same size, distance to the screen the same, my current screen the same size but the only difference is that I have a JVC RS45 projector. My current screen is a Grandview manual and like you will upgrade to a larger screen from 100 "to 120", likely somewhere in the middle.
I view a lot of 3D content and I am a little disappointed with the brightness in 3D only, 2D is fantastic . I would like to purchase a screen that though bigger by 20% would yield the same level of brightness
with a higher gain screen. If this is possible, please advise the screen
If you feel I am hijacking your thread I will move to another post. It just looks as though we are on the same mission here.
Dedicated Theater: Sony VPL VW 675ESB & JVC X950RU/RS600 , Panamorph DC1 Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 132" diagonal curved 36FT radius, Anthem 1120 AVR , 7.2.4 Atmos, Paradigm Monitor 11 fronts, Monitor 3 Center, Monitor V7 Rear, SA-ADP In-wall Surround, Niles DS-7 In-Ceiling, Subwoofers: (4000 watts peak) Klipsch RW-12 + SVS PC13-Ultra
roxiedog13 is online now
post #3 of 5 Old 01-04-2013, 01:31 PM - Thread Starter
mkedda's Avatar
Love the support now we need some responses!
roxiedog13 likes this.
mkedda is offline
post #4 of 5 Old 01-05-2013, 08:18 AM
tucsondave's Avatar
I have a similar set-up, ceiling mounted projector is 13 feet from a homemade screen. I am looking to upgrade.
Elite sent me a sample of their Airbright 5D by mistake but I tried it anyway.
Super bright in the center of the screen but if hung at the left edge and I sit even with the right edge of the screen it
was totally dark.
So beware of high gain angular reflective material when having a set-up like we have.
Elite is sending more samples of some other material for me to try. When I look at them I'll post back here.
td
tucsondave is offline
post #5 of 5 Old 01-08-2013, 07:34 PM
aligborat's Avatar
I also have similar room dimensions and am trying to figure out screen size. Are your screen measurements diagonal or width? And what's your post-calibration lumen output? What are your seating distances? You may find this thread helpful:
http://www.avsforum.com/t/1004723/chart-distance-x-screen-size-standards-smpte-and-thx
aligborat is offline
Reply Screens
