Advice Needed for Perforated (Woven?) Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-20-2013, 08:54 AM - Thread Starter
CraigS720's Avatar
I have been tasked with putting together a home theater for a friend. He wants a 120" diagonal screen and will use a new JVC X75 projector. Great sound is a must but doesn't want to to have speakers on the floor. I have recommended against in-wall speakers (it's the hard core audiophile in me :-) ) but I don't know if the projector will have enough light output for a screen that size with speakers behind the screen.
The room will be about 16' X 26'. New construction so everything is on the table.
Thoughts?
Craig
CraigS720 is offline
post #2 of 4 Old 01-21-2013, 07:52 AM
Audiojan's Avatar
Quoted: 18 Post(s)
Seymore Centerstage, Elite with either 4k or 1080-2 material, or you could go with something microperf from Stewart if you don't mind spending a bit more. Built a false wall (aka screen wall) and place the speakers behind the screen. Make sure all the surfaces in that area are properly dampened and blacked out.
"Suddenly the thought struck me, my floor is someone elses ceiling" - Nils Ferlin
Audiojan is offline
post #3 of 4 Old 01-21-2013, 11:42 AM
smuggymba's Avatar
Quoted: 113 Post(s)
Any link to info on creating a false/screen/baffle wall?
smuggymba is offline
post #4 of 4 Old 01-21-2013, 01:29 PM
Nyal Mellor's Avatar
Quoted: 463 Post(s)
Liked: 342
There is a little bit of material on baffle wall design in Procella's design guide. You can incorporate some cool lighting effects with screen walls (put lights behind the screen shining up at speakers).
With respect to the screen - I would aim for 28ftL for the screen brightness, that will allow for lamp dimming over the life of the projector whilst hitting the SMPTE / THX recommendations. Likely you'd need the 1.2 gain Seymour CenterStage XD material for that.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
Reply Screens
