unimpressed with Da-Lite samples - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-23-2013, 06:42 PM - Thread Starter
tothjm's Avatar
So I received a full compliment of the Da-Lite samples ( about 19 of them ) and i have to say, the majority look NO DIFFERENT from my white wall, and the few that did really did not make THAT big of a difference. A few popped out the blacks more, but the whites were trashed ( i know this is becuase of the comparison right next to it and my eyes will adjust )
my real question is... if i were to look at the DNP Supernova 08 and 23 materials... will i actually be wowed? becuase as it is there is no way i will spend 1000+ on ANY of the Da-Lite samples... i would just keep my white wall.
anyone else experience this and end up being really wowed by the DNP Supernova screens ?
tothjm is offline
post #2 of 12 Old 01-24-2013, 01:14 AM
cemo62's Avatar
Quoted: 48 Post(s)
tell me the model of dalite u use
cemo62 is offline
post #3 of 12 Old 01-24-2013, 08:22 AM
Mike Garrett's Avatar
Quoted: 5613 Post(s)
Liked: 3594
Any screen material that improves the blacks will reduce the whites also. The contrast of the projector is fixed. No screen can expand it. So if the darks get darker the whites also get darker. All you are doing is moving the contrast range, down or up the scale. If you are unhappy with the black levels, then a darker screen will improve that and your contrast spec stays the same, but comparing the whites on the darker screen to the whites on a white screens will always leave you disappointed. There is no way to get darker blacks and whiter whites, using the same projector, unless you improve the room.
Stuntman_Mike likes this.
mjgarrett100@gmail.com
Mike Garrett is offline
post #4 of 12 Old 01-24-2013, 08:42 AM
snyderkv's Avatar
Quoted: 185 Post(s)
Liked: 48
deleted
snyderkv is offline
post #5 of 12 Old 01-24-2013, 11:06 AM - Thread Starter
tothjm's Avatar
I am still curious if there is a bit more of a wow factor with the 08-85 DNP material
tothjm is offline
post #6 of 12 Old 01-24-2013, 11:15 AM - Thread Starter
tothjm's Avatar
well i use a white wall right now lol
but i tested about 19 samples... the only two that really stood out was the HD progressive 0.6 and the high contrast cinema vision 1.1
and to me even those were just meh.... perhaps i was expecting too much ?
tothjm is offline
post #7 of 12 Old 01-24-2013, 03:15 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3067 Post(s)
Liked: 2983
You must have an unusually smooth and uniform wall to equal a screen.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #8 of 12 Old 01-24-2013, 05:18 PM
noah katz's Avatar
Quoted: 887 Post(s)
Liked: 304
Including the HP and HPHC?
I can't imagine how you woyldn't see the obvious brightness difference.
That's true, but directional screens can certainly improve *image* contrast by increasing the amount of light reflected from the pj and decreasing the amount of light reflected from other directions.
Noah
noah katz is online now
post #9 of 12 Old 01-24-2013, 07:26 PM
snyderkv's Avatar
Quoted: 185 Post(s)
Liked: 48
Here is the 3010 onto the Blade 08-85 at night with high intensity lights shining from above. You can see the blacks are as black as the back wall and I can still read a book.
If this was a white wall, you would see nothing.
I used to do that in my room and was pretty much unwatchable with the lights on. Artificial light is were this material shines. Natural light is much more difficult but I can still watch non dark or non horror movies without complainling much
snyderkv is offline
post #10 of 12 Old 01-24-2013, 07:28 PM - Thread Starter
tothjm's Avatar
unfortunately those screen materials are not idea since the projector is ceiling mounted, and the viewing cone just isnt wide neough for my application =\
as for the smooth wall comment, lol, i guess so? I can go right up the test materials, and its the same as my wall, brightness and texture, so those were counted out right away
i have a sample of dnp supernova 23-23 coming which will arrive on the 29th i believe. I am curious if i will get any wow factor out fo that....unfortunately, i was not able to get 08-85 test material at this time =\ may have to wait a month for that.
tothjm is offline
post #11 of 12 Old 01-25-2013, 03:20 PM
Liked: 3594
And here I was trying to keep this simple. smile.gif Reflected light definitively makes a huge difference and why many people work so hard to reduce it in their dedicated rooms. Once you see a good high contrast projector in a good light controlled room (a room with no windows, does not make a light controlled room) you understand why people want this.
Noah is correct, the specialty screens are designed to reject off angle light and help very much in rooms with ambient light.
post #12 of 12 Old 01-25-2013, 03:43 PM
noah katz's Avatar
Quoted: 887 Post(s)
Liked: 304
My pj is 7' from the floor, so could qualify as ceiling mounted, and I get about 1.8 gain from my HP, though it's 22' pj to screen.
Use the screen calculator and enter your setup dimensions and see what you get.
Noah
Reply Screens
