Silveryscreen 10 gain screen??? - AVS Forum | Home Theater Discussions And Reviews
Old 02-14-2013, 03:45 PM - Thread Starter
AreasInteligent's Avatar
Anybody had any experience with the Silveryscreen 10 gain screen? I have been trying to get some samples to compare it to other screens. Im looking for a HDTV kind of brightness because there is a lot of light in the room and cant be controlled completely because it is a multypurpose gaming room with bar, pool tables, pocker and that stuff and i can only afford a DPI M-Vision Cine 260 HB projector with 4000 lm output for a 120 inch screen so i need a very high gain screen. But i find what they claim at their website to be like "Snake oil" it sounds to good to be true, besides i havent found much third party information about it. I have other options like Stewarts Firehawk 3G which i think its a good option because it is a grey screen with good gain so it can serve double purpose to improve brightness and black levels. Other options might be SI black dimond 2.7 but i think the biggest size is 115". So what do you guys recomend?
AreasInteligent is offline
Old 02-14-2013, 06:27 PM
henrich3's Avatar
Quoted: 428 Post(s)
Liked: 370
henrich3 is offline
Old 02-14-2013, 08:19 PM
airscapes's Avatar
Quoted: 305 Post(s)
Liked: 260
http://www.avsforum.com/t/228371/the-high-gain-exotic-screen-review/0_100
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 02-15-2013, 11:05 AM - Thread Starter
It looks like an amazing screen but i dont think there are any dealers in Mexico and getting one in the US or EU and bring it to Mexico would make it really expensive.
But there are many Stewarart dealers and i see many people comparing the image to the Firehawk 3G which i have seen many times in other setups and the image is great.
Im going to try to get some samples of this DNP to compare.
Thanks for your help
Old 02-15-2013, 11:07 AM - Thread Starter
I had already seen this thread, thanks. But it was so long ago and so many companies have now so many newer products that it is hard to use this information as basis to make a desicion. Thanks alot for your help anyway.
