DNP vs. challengers - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 108 Old 07-13-2013, 08:12 PM
PSHK's Avatar
What is the general feedback on DRAPER REACT 2.1 ?
Would appreciate any views on its performance compared to DNP (both materials), SI BLACK DIAMOND....and any other challengers.
Personally, I have tried samples but this may not be reflective of the real screen as needs to be tensioned to work its magic.....and without tensioning, it really did raise the concern on viewing angles with notable shifts in brightness when moving around.
Lots of forum talk over the Atlantic on Draper React 2.1 as being better than DNP and as good as BD without sparkles and for significantly less $$$$ ...yet, there seems to be very little reference to this screen in this forum.
.....is the react 2.1 a potential undiscovered Gem in the US...or has it already been reviewed, compared and dismissed........
PSHK is offline
post #92 of 108 Old 09-09-2013, 03:29 AM
Matrixfan's Avatar
I have a question to those who find 0.8 not bright enough for 3D. Are your findings based on circumstances with ambient light, or is it also dim for dedicated movie watching in the dark with no ambient lights on?
Matrixfan is offline
post #93 of 108 Old 09-10-2013, 03:46 PM
Johnrecon's Avatar
Here in Sweden the React is quite a popular HC screen.
It does the job very good but no match to a BD or DNP regarding lots of ambient light (Side-Ceiling).
I have a 2.0 and for the price it is a very good screen. Shine is there but it is not extreme, I would say comparable to a FH and BD.
The DNP is a totally dif screen, No shine and a very wide view angle 180deg ish. and it dampers reflection towards the ceiling/floor very good.
On a side not, during a blind test i compared the FW, BD, DNP, REACT and Multipix. we tested blacks, whites, shine, angle and reflection.
From best to worst: DNP 0.8, BD 0.8, React, FH, Multipix.
Figures:)
Johnrecon is offline
post #94 of 108 Old 09-11-2013, 10:52 AM
dougri's Avatar
Quoted: 45 Post(s)
Liked: 52
Figures:)
How would you rate each in rejection of side vs ceiling light? I'd assume a different screen would be warranted if you are more worried about ambient light from windows than reflected light from a white ceiling... no? If both (light colored room with lots of windows), would a simple retroreflective screen like dalite HP be better than these?
dougri is offline
post #95 of 108 Old 09-12-2013, 10:12 AM
Johnrecon's Avatar
I Would say that the BD 0.8 handles ambient light as good as the DNP but on all sides instead of only ceiling/floor. at the cost of a smaller viewing angle of course.
post #96 of 108 Old 10-12-2013, 07:34 PM
PSHK's Avatar
Figures:)
PSHK is offline
post #97 of 108 Old 10-12-2013, 07:40 PM
PSHK's Avatar
Good to hear that the React 2.1 is popular in Sweden, and appreciate the feedback on comparing to other screens.
I was originally leaning towards the DNP, however as I would be looking for an electric screen that would have regular use, I was concerned on other feedback regarding ripples over time... Whereas the react screen had tab tensioning and from users reports was very good at maintaining continuously flat.
Any thoughts / experience of such issues with the DNP?
PSHK is offline
post #98 of 108 Old 10-13-2013, 11:45 PM
karlsch's Avatar
Quoted: 20 Post(s)
Liked: 24
Draper USA introduced the ReAct MS1000V at CEDIA 2013:
http://www.draperinc.com/projectionscreens/ReAct.asp
Probably similar to or the same as what is called ReAct II in the UK market and, as mentioned previously in this thread, has been available there for several years.
I would like to replace my BD 0.8 with something that doesn't have the BD's sparkles and hot spotting and isn't as expensive as the DNP. I wonder if this could be it.
Karl S.
karlsch is offline
post #99 of 108 Old 10-14-2013, 09:02 PM
Ranger's Avatar
Nice find. This is the ReAct 2.1 screen made by Euroscreen for Draper Europe. I thought about importing one from the UK but it was quite expensive. Hope we get a better deal now.
http://www.euroscreens.se/home-3/products-2/grupp/fixed-framed-screens.aspx?pid=60&aid=78&dss=true
Ranger is offline
post #100 of 108 Old 10-18-2013, 10:13 AM
dougri's Avatar
Quoted: 45 Post(s)
Liked: 52
Originally Posted by noah katz View Post
ah I forgot dougri is local
Doug, do you want to come and get them? I'm just a few miles from NASA/Ames
How did I miss this?!
Do you still have the samples, Noah? I have a 2.8HP 106" 'portable' screen I'm using right now in my living room (with white ceiling, light walls and plenty of windows), and have the newer 2.4 HP and HCHP samples as well (and an Elite power gain fixed frame screen behind some shelves in the garage collecting dust... it does not exhibit any sparkles currently). If you are still 'a while' out on your HT endeavor, I'd be happy to take some photos of the samples. Otherwise, your setup (and existing screen) sound almost identical to mine.
dougri is offline
post #101 of 108 Old 10-18-2013, 11:15 AM
noah katz's Avatar
Quoted: 879 Post(s)
Liked: 304
Yes, still have them.
I'm really close now; just finished building and hanging 4 additional surround speakers, and building the new center channel today (old one is too tall now).
I'm tentatively scheduled to consult with Curt Hoyt next week to get the Trinnov Optimizer tuned up.
So just hang on a bit longer...
Noah
noah katz is online now
post #102 of 108 Old 11-04-2013, 07:58 PM
PSHK's Avatar
Has anyone tried the new material from Draper. Ms1000v ( which should be same as react 2.1 from Europe )
Would be good to see opinions / views....
PSHK is offline
post #103 of 108 Old 11-05-2013, 01:21 AM
Skylinestar's Avatar
Quoted: 1044 Post(s)
Liked: 182
The problem is MS1000V could be different from ReAct2.1...at least on Ranger's test sample. mad.gif
Skylinestar is offline
post #104 of 108 Old 11-05-2013, 05:21 PM
PSHK's Avatar
Based on specs of the material, I think they appear to be the same...with US finally getting the same material that has been available in Europe for a while now.
PSHK is offline
post #105 of 108 Old 11-28-2014, 10:59 AM
Sam Ash's Avatar
Quoted: 216 Post(s)
Question Draper ReAct 2.1
I know this is an old thread but surely someone here is using the ReAct 2.1 by now - how does it perform ?
Sam Ash is offline
post #106 of 108 Old 11-29-2014, 08:18 AM
ader42's Avatar
Quoted: 24 Post(s)
Liked: 26
Hi
The best resource I know of for reviews/discussion of React 2.1 is:
https://www.avforums.com/threads/dra...ested.1604732/
I've seen it in action and it is good. I'm not convinced it's better than DNP SuperNova but equally it doesn't cost as much as the DNP screens.
I haven't bought one for the new place I live for a few reasons really:
1) I now project onto a matt white wall and don't need a retractable screen.
2) I 99% use my JVC X3 at night.
3) To get the best out of a React screen you want a projector with more lumens than my X3.
4) Getting a brighter projector won't suit my environment as the walls/ceiling are white and staying white. I think a brighter projector in my room would be bad news irrespective of screen.
5) To me it just looks more impressive without a screen, I watched Winter Soldier last night and I'm still as impressed with my X3 as when I bought it almost 4 years ago.
I think a DNP SuperNova 0.8 would suit my purposes better if it wasn't for not needing a retractable screen and 0.8 gain not being suitable for 3D.
I wonder how NoahKatz is getting on with his room?
ader42 is offline
post #107 of 108 Old 12-04-2014, 02:07 PM
BakeApples's Avatar
Quoted: 245 Post(s)
Liked: 139
React 2.1 has visible texture, Supernova 0.8 does not.
So far, i havn't seen any material even close to the DNP but i'm still looking, DNP is way too expensive for me so i'm looking for an alternative material with close to or equal properties as the Supernova.
Have anyone seen the new Matinee Black material from Seymour yet? If so, how does it compare to DNP?
BakeApples is online now
post #108 of 108 Old 12-06-2014, 06:25 AM
Sam Ash's Avatar
Quoted: 216 Post(s)
Would be nice to get more info the Matinee by Seymour AV, anyone seen it in action ?
Sam Ash is offline
Reply Screens
