Is bigger better? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-26-2013, 07:05 AM - Thread Starter
MrGreeno's Avatar
I've done a lot of reading and I can't seem to find a definitive answer to my question, so I put it to the fine folks here.
The room is 15'x19'.
No ambient light (all user controlled).
The projector is an Epson 8350.
I was planning on going with the 120" Sable frame from Elite, Cinewhite 1.1 gain.
Should I pony up a bit extra and go with 135"?
From what I can understand, if I go bigger, I have to lengthen the throw distance from 16'2" to 18' which would lower my brightness.
Am I missing something or would I be sacrificing quality for size?
A toast to Bill Brasky!
MrGreeno is offline
post #2 of 9 Old 02-26-2013, 07:31 AM
kumanzc's Avatar
Quoted: 23 Post(s)
According the projector pro calculator your throw range for a 135" image is between 13'3" - 28'2" so you could still leave it at 16ft. WIth a 120" screen you would have 15 fL and at the same distance with a 135" screen you would have 14 fL.
kumanzc is online now
post #3 of 9 Old 02-26-2013, 08:35 AM
airscapes's Avatar
Quoted: 257 Post(s)
Liked: 218
Are your walls, ceiling and floor DARK, if not you do not have a light controlled room and reflected light will wash out your image big time. The closer the screen is to light colored walls ceiling and floor the worse it will be.
Did you look at the info online about seating distance and size rules of thumb?
Did you calculate the approximate light output you will get from each screen size? 16fl or more is the target and it will drop a lot after calibrations and 500 hours of use. http://www.projectorcentral.com/projection-calculator-pro.cfm
Have you projected the image on the wall and measured it to see what you like?
Have you taken into account speaker placement including center with each screen size?
Have you calculated how close the the floor the screen will be (to low is bad for viewing especially if you have a second row)
No one can tell you what you should do, you have to figure out what you like and what will provide the best image and make whatever compromise you are willing to make with the room conditions and projector ability you have.
Good luck!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 9 Old 02-26-2013, 08:45 AM
JoeBoy73's Avatar
Liked: 26
I would check out some of the posters on the 8350 forum with large screens. I'm sure there are several people with 135" and up screens with this PJ. I will say this...my neighbor has this PJ on a 110 fully light controlled room and the picture is washed out! Dark walls and Ceilings make a huge difference, especially if you plan on going big...
JoeBoy73 is offline
post #5 of 9 Old 02-26-2013, 09:58 AM
domingos38's Avatar
Liked: 35
I had this projector with a 130" screen in a light controlled room with DARK walls ,ceiling and floor and it looked awesome.
so yes white walls and ceiling will make pic look like crap
domingos38 is offline
post #6 of 9 Old 02-26-2013, 11:37 AM - Thread Starter
MrGreeno's Avatar
Thank you everyone..
Looks like I'll need to recalculate and make sure my seating arrangement will still work.
The room will be DARK. Flat black on ceiling/screen wall, dark maroon on the walls and black carpet.
MrGreeno is offline
post #7 of 9 Old 02-26-2013, 12:08 PM
Home Theater Lover!
Craig Peer's Avatar
Quoted: 1661 Post(s)
Liked: 1423
You would be surprised how big an improvement this makes picture quality wise.
AV Science, Inc. Direct (585) 671-2972 craig@avscience.com www.avscience.com
Home theater equipment sales and advice. Call to see the JVC RS600 in Northern California
My theater pics - http://www.avsforum.com/photopost/sh...hp?cat=2386514
Craig Peer is online now
post #8 of 9 Old 02-26-2013, 03:41 PM
noah katz's Avatar
Quoted: 629 Post(s)
Liked: 238
If the pj stays in the same place, throw *ratio* decreases and the pj will put out more light.
This mostly compensates for the dimming larger screen area would give with the same lumen output; when I zoom my JVC RS10 for changing between 1.78 nand 2.35 I don't perceive any difference in brightness.
re your original question, I'd say go bigger unless you're going to be closer than 1.25 screen widths.
If you already have the pj, try both sizes on the wall.
Noah
noah katz is offline
post #9 of 9 Old 02-27-2013, 05:47 AM - Thread Starter
MrGreeno's Avatar
If I'm reading the calculator correctly then light output for 135" @ a throw distance of 15' should be about 16fL which appears to be on target.
Front row seating is planned at 10' with the second row around 15'.. I'll scoot these back a bit and I should be good to go.
Since I'm using towers for front and rear speakers, the only speakers I'd need to move are the sides.
Luckily I'm still in the demolition phase so I can get all this hammered out before I start buying sheet rock, which should be soon!
MrGreeno is offline
Reply Screens
