Best Budget 100" Fixed Screen that is $500 or less and 1.0 gain? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-09-2013, 08:03 PM - Thread Starter
Fast GTO's Avatar
Looking to pick up my first projector and would like to stay $500 or less on a white screen with 1.0 gain.
Not sure what all the options are.
Fast GTO is offline
post #2 of 2 Old 03-10-2013, 06:40 AM
rekbones's Avatar
Quoted: 479 Post(s)
Liked: 248
I am very happy with my Jamestown 110" cinewhite 1.2 gain screen gotten for half of your $500 delivered. Unless James has solved his backlog problems be prepared for a 3 month wait (it was still worth it). Solid 3 1/2" frame covered with real black felt and great screen material. Very much like a custom home made frame. The elite ez-frame screens are OK if you want a good comercial grade frame with a sprayed on felt covering, smaller frame, and not as good screen material for a little more money but get in a few days.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
Reply Screens
