NR: newbie need advice on first screen for Epson 3010 projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-17-2013, 08:09 AM - Thread Starter
gh0001's Avatar
here is my setup:
- Epson 3010 projector, ceiling mounted with lens to screen distance of 13' 1''
- room size is 15' 6'' X 23'11'', height = 8'6'', at basement, good light control
- viewing distance is a bit flexible, probably 13 to 16'
- watch movies including 3D
- looking for 133-136in screen (pls advice is this is not the ideal size)
advice on the following would be appreciated
- screen color (black or gray screen)
- screen gain
- anything else including brands?
Thanks a lot!
gh0001 is offline
post #2 of 6 Old 03-17-2013, 07:20 PM - Thread Starter
gh0001's Avatar
BTW the room is dedicated to entertainment in the basement. thanks.
gh0001 is offline
post #3 of 6 Old 03-19-2013, 10:25 PM
DrZaus's Avatar
Originally Posted by gh0001 View Post
here is my setup:
- screen gain
Check out the projectorcental calculator pro and put in your information... http://www.projectorcentral.com/Epson-PowerLite_Home_Cinema_3020-projection-calculator-pro.htm
You should be okay with a 1.0 gain matte white screen.. I could not find your 3010 projector so I calculated with a 3020.. you may want to ask other for opinions.. i'f you on a limited budget check out Jamestown and Monoprice.. great screens..
DrZaus is offline
post #4 of 6 Old 03-20-2013, 12:44 AM - Thread Starter
gh0001's Avatar
Thanks DrZaus. The link is very helpful.
It seems the tool is mainly for non-3D? my understanding is that for 3D the brightness is lower so I am wondering if a higher gain screen is needed.
what are the tradeoffs between
- higher vs. lower gain
- white vs. gray
thanks!
gh0001 is offline
post #5 of 6 Old 03-20-2013, 09:51 PM
DrZaus's Avatar
- white vs. gray
thanks!
Yes it's main for non 3d, but you can use it for 3D also, room should be dark or have light control.. There are many useful threads for what your looking for..
Describe your setting/surrounding.. If you want to do 3d, get a screen with a higher gain.. but you need to have light control and darker walls.. What is your budget for the screen?
DrZaus is offline
post #6 of 6 Old 03-25-2013, 09:36 AM - Thread Starter
gh0001's Avatar
It is in my basement. If I close the blinds the room will be completely dark. The wall is light brown with Matte finish. To do 3D what gain should I use? What are the tradeoffs? Thanks!
gh0001 is offline
Reply Screens
