is this screen any good need help screen noob - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-18-2013, 01:45 PM - Thread Starter
killerzebra's Avatar
Right now im using a white wall with my optima hd20 no special paint was painted before i moved here still looks good wall is in great shape
http://www.elitescreens.com/index.php?option=com_content&view=article&id=16&catid=1&Itemid=19&lang=en.
i need a 125in to 135in it does not have to move up and down can bee fixed want to stay under $ 400
killerzebra is offline
post #2 of 2 Old 03-23-2013, 01:55 AM
havok2022's Avatar
I wouldn't suggest that screen if you can use a fixed screen instead. You can get and Elite fixed screen for close to your budget. It will look more professional and more importantly the screen will stay taught. The pull-down and drop down screens will eventually ripple over time and cause waves in your picture. You can avoid this by getting a tab tensioned drop down, but those are generally out of your budget. Typically these are used for dropping in front of another TV for standard tv watching and screen for movies, or in areas where a fixed screen won't work. Since you can go fixed, go fixed.
LG 55EC9300 - MartinLogan Ethos - MartinLogan Motif X - B&W 685 S2 - B&W AWS610 - Anthem AVM60 - Parasound A31 - Parasound Zamp v3 - Oppo UDP-203
havok2022 is offline
Reply Screens
