Screen and universal ceilling mount to go with a Benq W7000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-18-2013, 06:14 PM - Thread Starter
deekay08's Avatar
Hi all,
I'm new to the projection world... just bought my self a benq W7000, now the thing is I need a screen... found a 120'' Granview cyber series with manual pull down with soft close... can anyone tell me if they've used or know if these are good products, seems pretty good made of 4 fiberglass layers to avoid waves over time in it... this to be installed in a 16' wide x 23' long room... projector would be placed around 17' from projection screen. as for mounting the projector I found a universal bracket Anchor mount model # ACM PM12 BK, seems pretty easy to install and seems well made
here's a view of the wall the screen will be placed as you can see the ceilling is not done yet... it will be suspended ceilling to come cool.gif
let me know anyone who have advice on these
deekay08 is offline
Reply Screens
