AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Screens (http://www.avsforum.com/forum/23-screens/)
-   -   JVC RS40U - Best match for screen material (http://www.avsforum.com/forum/23-screens/1464710-jvc-rs40u-best-match-screen-material.html)
Steve*MH 03-22-2013 09:46 PM
I am looking for a good screen material match for my JVC RS40. I have a dedicated HT room that is completely light controlled. I am looking at a 120" fixed screen with a throw distance of just under 20'. My family does like 3d and we do use it on occasion. I would really like something that is effective with 3d and 2d. The lumens of the JVC are not tremendously high - so looking for something with some higher gain, but also decent for off-axis viewing. The Da-lite High Power 2.4 gain has received some good reviews and is tempting, but not sure if it is "too much" gain. I am also using the Xpand 104 glasses, so I need a screen that does not retain polarity. Any other recommendations for screens, perhaps in the 1.3 to 1.5 gain range? Or is the Da-lite High Power perhaps a perfect match for the JVC RS40?
Thanks for any recommendations.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
