JKP 1.1 in the house - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 74 Old 09-23-2013, 01:43 PM
CRAZZZY's Avatar
Finally had a chance to put my Da-lite Hd progressive 1.1 screen and WOW. This just replaced my aging high contrast cinema vision and the difference is dramatic. The screen texture and shimmering that bothered me is completely gone. Never noticed that my whites wern't really white until viewing the new Hd screen. The image now is so clean with nothing distracting me also being a white screen, my image is brighter with more "pop". This was an upgrade to prepare for my eventual upgrade to a 4k projector but I have to say, this is the best I have ever seen my projector look.
Details in case anyone is interested. 80" wide screen, 10.5 feet to seating position. Black ceiling, floor, with dark color side walls. Fully light controlled. 13.5 feet throw distance for the Sharp xv-z20000 dlp projector. Older projector but definitly aging gracefully.
Ck
I'm no videophile, but I know what looks good to me.
CRAZZZY is offline
post #62 of 74 Old 09-23-2013, 02:29 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 2691 Post(s)
Liked: 2484
Congratulations on the new screen. Sounds like you are experiencing what other owners have reported !
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #63 of 74 Old 10-09-2013, 08:06 AM
iBob57's Avatar
Just to add to the database on this very high end screen material from Da-Lite...
Last night I completed a swap-out of the roller/screen on my 106" Da-Lite tensioned Cosmopolitan Electrol. The original screen material was Cinemavision 1.3. The replacement is HD Progressive 1.1. I have been planning to replace either the fabric of the entire screen for some time now as the original Cinemavision material had developed the dreaded "stickness" syndrome a couple of years ago and I was tired of wiping the thing down with denatured alcohol every 6 months.
As has been universally reported by others here, the difference the HD Progressive fabric made compared to the Cinemavision was immediately noticeable. The projector is a Pioneer Elite FPJ-1 (JVC RS2 clone). The Projector lamp was replace fairly recently, having only around 100 hours on it.
I have always considered the Cinemavision fabric to be a good choice for home theater. However, I now "see" deficiencies that I did not even know were there until they were gone. Uniformity of color and brightness are noticeably improved which lends a very smooth, more film-like look to the image. There was a slight "harshness", for lack of a better description, to the Cinemavision screen that has disappeared with the new fabric. I do not see any decernible loss of brightness with the slight drop in gain, and black level is at least as good, if not better.
I have been thinking recently about replacing the Pioneer projector with a newer JVC, and I know there would be some improvement with a newer model. However, I have to say this new screen has given the workhorse RS2 chassis a new lease on life. I was consistently impressed with the look of both Blu-ray and HD broadcast images staying up way past my bedtime last night. I'm looking forward to revisiting a stack of favorite Blu-rays this evening for some more in-depth assessment of the new screen.
Anyone considering a high quality screen should give the HD Progressive serious consideration. I've looked at a lot of front projection in all types of applications. I have not seen any home theater screen that I could say is better than this.
One note regarding this application. Da-Lite does not normally offer this fabric with the Cosmopolitan screen. The roller/fabric made for me was a custom build. I happen to work for a company that does considerable commercial business with Da-Lite. They did me a favor.
iBob57 is offline
post #64 of 74 Old 10-09-2013, 11:36 AM
Plasticfish's Avatar
Originally Posted by Craig Peer View Post
I got some large samples of the new HD Pro 1.3 materia yesterdayl. Good looking stuff. Whiter than the 1.1 material. I'll have to do some experiments with it in my theater.
Hey Craig...any thoughts on the new 1.3?
I am looking for a screen to go with the new Sony 500/600....short-listed are the 1.1, the 1.3, and the Carada BW (price puts this screen on the short-list)
Interested in hearing your thoughts on the 1.3
Plasticfish is offline
post #65 of 74 Old 10-09-2013, 11:44 AM
Gagorian's Avatar
I'm also enjoying my 133" JKP 1.1. It's a clear upgrade from my previous 119" High Power (2.4) screen. Here's some quick comparisons between the JKP 1.1 and the High Power 2.4 surface.
Pros:
1. This is by far the main reason for why I switched: My High Power screen had clear and distracting uniformity issues (I had my High Power screen replaced twice - issue persisted), there were both horizontal and vertical banding visible in bright scenes, especially if the camera was panning. The JKP surface has -almost- no visible banding (there are a few very faint vertical faint lines due impressions from the roller when the screen is kept rolled, they mostly disappear after the screen has been rolled down for extended periods).
2. My Sony HW50Es has slight white field uniformity issues, but they are less visible on the JKP 1.1.
3. The image also seems smoother, or even sharper as the surface is much smoother. There is less of a sheen/grainy effect of the surface.
Cons:
1. I do miss the brightness of the High Power screen and I had to turn my lamp from low to high. 3D isn't as bright either.
2. Ambient light rejection is clearly worse. For me this isn't such of a big deal as I really don't enjoy watching movies/series with any ambient light as it just kills the contrast, even if the option would be "nice to have"
3. Even with the lowered gain I think the black bars in widescreen movies have slightly elevated blacks due to ceiling/wall/floor reflection (even if my room is mostly light controlled for the first 2.5 meters from the screen). This can be fixed by improving reflection control wink.gif
In the end, I'm very happy with the switch.
Gagorian is offline
post #66 of 74 Old 10-09-2013, 03:52 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2484
You did get a somewhat larger screen too, over the previous High Power. Glad you are enjoying it.
post #67 of 74 Old 10-21-2013, 05:23 PM
nannandong's Avatar
i think so,I would have never thought the Mitsubishi HC7800 would look this good,thanks
nannandong is offline
post #68 of 74 Old 10-21-2013, 05:31 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2484
I haven't had time to really test it compared to my StudioTek 130 screen. It looks somewhat similar though. I'll try and do some testing this week. And I'll try and test the HD Pro 1.1 against the Stewart Cima Neve 1.1 too.
Plasticfish likes this.
post #69 of 74 Old 11-01-2013, 08:06 AM
Gagorian's Avatar
Originally Posted by noyesokno View Post
good,Going from the Studeotec 130 was a night and day level improvement in realism and having the screen surface completely disappear.
rc
I'm not sure I understand what you mean. Do you mean you swapped the StudioTek 130 to a JKP 1.1 screen?
Gagorian is offline
post #70 of 74 Old 11-02-2013, 02:00 AM
08-450dually's Avatar
Hi Craig. I, for one, would love to hear your thoughts when comparing the JKP 1.1 to the Stewart Cima 1.1
Hope you get to that soon!
Jaime
08-450dually is offline
post #71 of 74 Old 11-02-2013, 08:13 AM - Thread Starter
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Looks like that is what he did from his post.
greg1292 is offline
post #72 of 74 Old 11-04-2013, 06:34 AM
flybikeusas's Avatar
just so so,the .9 gain might be your best choice, depending on your projector and screen size.thanks
flybikeusas is offline
post #73 of 74 Old 11-06-2013, 06:04 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2484
Jaime
It's a tough call. I have another set of samples coming, and I'm building a new screen sample holder to better test screen samples. So far they are very close as far as I can tell. Stay tuned for more testing.
post #74 of 74 Old 01-27-2014, 09:12 PM
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
did anyone get the jkp 1.3? wondering what full screen impressions are
My theater build : Roll-In Reels Cinema (7.2.4 atmos theater)
lpnaz480 is offline
Reply Screens
Mitsubishi Hc7800d Projector Full Hd 3d Projector
