JKP 1.1 in the house - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 109 Old 04-04-2013, 08:55 AM - Thread Starter
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Well I recently bought a Mitsubishi HC7800D and was viewing on what I thought was a very
good S-I-L-V-E-R and noticed lack of focus and a ton of noise in the image. So I started out
looking for a screen to do 2D/3D and ended up going with a 106" JKP 1.1 screen.
The reason is my room is total light controlled and black and nonrelective treated walls and
wanted to see an image with very good whites/color/ and focus. My previous HP screen was
very good and I thought bright or that plasma pop but had enhanced noise in the image. Being
that I sit 11ft back this noise really bothered me and since have read that I needed to sit
further back which is not an option in my theater.
My initial findings running the projector in low lamp mode this screen has plenty of pop and a
very clean and detailed image. Noise is all but gone and the projector looks fantastic. If I were
to describe the picture it would be real and life like another word would be natural. Now I know
I only watched 2 hours on the screen and the projector has 25 hours but this is a very good
combination DLP and JKP.
The thing that struck me was how uniform and bright the image was with excellent detail
and focus and how pure the picture looked never got this with my previous screens.
Tonight I am going to test 3D and going to see if the same holds true.
greg1292 is online now
post #2 of 109 Old 04-04-2013, 03:18 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3032 Post(s)
Liked: 2962
Thanks Greg for the update. I have a sample of this material and I think its one of the best that Da-Lite currently offers. I'll assume you mean 106" diagonal. Can you comment on any visible screen texture or sheen from your seating distance? Thanks! smile.gif
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #3 of 109 Old 04-04-2013, 09:32 PM - Thread Starter
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
I see no sheen from my close seating it is a very clean image. Pixels are nonexistent and there seems to be a clarity to the
image I have never seen. I am glad I went with the 1.1 over the .09. I never knew that a screen made this much difference.
Every movie looks real like the movie is coming out of the screen! I thought the high power was good where that screen was
brute force the JKP is like a smooth cigar. I would have never thought the Mitsubishi HC7800 would look this good. If you
have anymore questions I will try to answer them. Oh I forgot zero texture smooth as silk.
post #4 of 109 Old 04-05-2013, 08:06 AM - Thread Starter
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Watched the Avengers in 3D last night in low lamp mode and was plenty bright
on the JKP 1.1 in low lamp mode. Excellent 3D viewing tried hi lamp mode but
there was no need.
post #5 of 109 Old 04-05-2013, 09:49 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 2962
Yes, the screen can make a big difference. The sample I have is very smooth and uniform, but having these observations on a full sized screen is even better of course ! smile.gif
post #6 of 109 Old 04-05-2013, 09:57 AM - Thread Starter
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
post #7 of 109 Old 07-09-2013, 04:18 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2962
Anybody else get one of these screens lately ?
post #8 of 109 Old 07-14-2013, 01:20 AM
blee0120's Avatar
Quoted: 429 Post(s)
Liked: 227
I have a sample and it looks very good. I'm thinking about getting one. I also have a carada cw in my room and the jkp 1.1 looks much smoother. I was discouraged from buying one but I think I might get one still.
blee0120 is offline
post #9 of 109 Old 07-14-2013, 06:34 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
In my NOSHO, the JKP .9 and 1.1 are two of the very best reference quality screens out there. The material is textureless.. The third contender s the Stewart Snomatt 100 (1.0) gain. The JKPs may even have less texture than the Snomatt which has a minute amount which is not visible. The Stewart has slightly better uniformity in gain . Since I already owned a four way masking Stewart, I rescreened with the Snomatt. Going from the Studeotec 130 was a night and day level improvement in realism and having the screen surface completely disappear.
mark haflich is offline
post #10 of 109 Old 07-14-2013, 05:40 PM
blee0120's Avatar
Quoted: 429 Post(s)
Liked: 227
Mark, if you have seen them both, do they have any sheen at all? I have samples but haven't got around to using them. I heard that they do, but by looking at them, I can not see how. I had a SI Gamma 4K reference screen and the sheen and texture was visible on bright scenes. I seen a little from my HP screen also.
blee0120 is offline
post #11 of 109 Old 07-15-2013, 05:08 AM
Gagorian's Avatar
I have also placed an order for a 133" JKP 1.1. I'm not happy with my HP 2.4 screen, the screen has distracting visible dark streaks/texture during bright scenes. I even had the HP swapped twice and the problems still appear (the streaks/texture were different in every screen), Da-Lite was kind enough to allow me to pick another fabric instead.
I will post my observations compared to the 2.4 High Power once I receive the new screen.
Gagorian is offline
post #12 of 109 Old 07-15-2013, 06:05 AM
Liked: 1010
Please give me a call and we can discuss this question.
post #13 of 109 Old 07-15-2013, 04:50 PM
blee0120's Avatar
Quoted: 429 Post(s)
Liked: 227
Ok, no problem
blee0120 is offline
post #14 of 109 Old 07-15-2013, 06:12 PM
mbw23air's Avatar
Quoted: 154 Post(s)
Liked: 140
Gagorian,
Look forward to your impressions comparing the JKP 1.1 vs the 2.4 HP.
Mike
JVC RS600(Calibrated with Chromapure using an iD3), Stewart Cima Neve 2.35 115" diagonal screen, Lumagen Radiance XD, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Panasonic UB-900 UHD blu-Ray player, HDFury
mbw23air is offline
post #15 of 109 Old 07-16-2013, 04:25 AM
biliam1982's Avatar
Quoted: 340 Post(s)
Liked: 164
When did you order your screen? Or when was the last time you had it swapped out?
I got a HCHP a couple months ago and had them do another QC check on it before it shipped to make sure it wouldn't have those issues.
biliam1982 is online now
post #16 of 109 Old 07-17-2013, 12:18 AM
blee0120's Avatar
Quoted: 429 Post(s)
Liked: 227
I finally got around to looking at my samples to pick my next screen. Before I taped them to my carada cw screen, I really liked how smooth the jpk 1.1 and .9 material was but the da lite da mat was almost just has smooth. There was a slight texture to it, but a little less than the carada cw. First I compared the Jamestown and carada cw and I liked the carada but the Carada isn't worth 3x the cost. Then I put the jkp screens up and I preferred the jpk screens. Next I put the da mat screen in the middle of the jkp .9 screen and I could not tell the difference from them at my 11.5ft seating distance. They actually look like the same material. I think this might be my next screen and I can get it much cheaper than the jkp and carada screen.
blee0120 is offline
post #17 of 109 Old 07-19-2013, 11:34 AM
rac2656's Avatar
I'm a newbie here and have had the JKP 1.1 133" for about 1.5 months in a dedicated theater paired with the Sony HW-50 and have to say it is absolutely awesome. Still getting everything dialed in but so far so good. Thank you Craig at AVS for your suggestion on a great screen.
rac2656 is offline
post #18 of 109 Old 07-19-2013, 01:38 PM
TL5
TL5's Avatar
Quoted: 51 Post(s)
Liked: 35
I'm looking to upgrade my screen from what I have - a 92" Da-lite Cinemavision, to a 100" Da-lite Cimena contour. Need help with screen selection. The throw is about 11 feet, right now I'm using a JVC RS-1 but plan to upgrade to either Sony HW50ES (or it's upcoming replacement) or a JVC RX55. Room has some ambient light in daytime (only really watch football in daytime), ceiling is light colored but walls are dark. Was looking at the JKP 1.1 material - do you have to use it in a batcave, or is it OK with some ambient light? If it's not suitable, any other suggestions preferably from the Da-Lite line? I see a grain in my Cinemavision on light colored field, would like something smoother if possible.
Thanks!!!
TL5 is online now
post #19 of 109 Old 07-19-2013, 09:51 PM
y2k02c5's Avatar
Quoted: 25 Post(s)
I'm currently in the process of swapping my screen out as well, and the JKP 1.1 was one of the potential options along with the Da Lite Da Mat 1.0.Currently I have Da Lite 119" High Contrast Grey Da Mat 0.8 gain with an Epson 5020. I thought it looked good until recently having my setup ISF calibrated.
Given that I can swap out the screen only, and keep my existing frame, going this route was more efficient from a price standpoint.
Looking forward to other feedback and if anyone can post up some screenshots, that would be great.
y2k02c5 is online now
post #20 of 109 Old 07-19-2013, 10:01 PM
blee0120's Avatar
Quoted: 429 Post(s)
Liked: 227
I say first get samples, you would be surprised at how similar the DaMat and jkp is. The jkp is a bigger sample, so you can place the DaMat sample in the middle to have a good comparison
blee0120 is offline
post #21 of 109 Old 07-19-2013, 10:41 PM
y2k02c5's Avatar
Quoted: 25 Post(s)
do you get the samples directly from dalite ?
post #22 of 109 Old 07-19-2013, 11:39 PM
biliam1982's Avatar
Quoted: 340 Post(s)
Liked: 164
Yes, shoot them an email asking for samples of which materials you're considering and your shipping address. They are pretty quick about getting them out.
info@da-lite.com
post #23 of 109 Old 07-20-2013, 10:51 PM
y2k02c5's Avatar
Quoted: 25 Post(s)
info@da-lite.com
Cool. Thanks for the info
post #24 of 109 Old 07-22-2013, 09:27 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2962
Enjoy your setup - nice combo! Your going to have that screen for many years. When you finally get to a point in the future when you might upgrade your projector to a true 4K machine, that screen will still be the perfect screen, and will work great without adding artifacts or detracting from the picture. The sharper and better the projector, the more you need a screen that doesn't add its own problems. IMO, you've got that screen. smile.gif
post #25 of 109 Old 07-24-2013, 12:42 PM
y2k02c5's Avatar
Quoted: 25 Post(s)
would you say if there is a noticeable diff between the 1.1 and the 0.9?
post #26 of 109 Old 07-24-2013, 04:16 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
Yes.
B.
Brian B is offline
post #27 of 109 Old 07-24-2013, 05:55 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2962
Absolutely. Side by side they are different materials. And different color wise. Get samples sent to you - free from Da-Lite.
post #28 of 109 Old 07-24-2013, 08:32 PM
blee0120's Avatar
Quoted: 429 Post(s)
Liked: 227
Its a difference but you can always get samples to see for yourself
blee0120 is offline
post #29 of 109 Old 07-25-2013, 04:50 AM
TL5
TL5's Avatar
Quoted: 51 Post(s)
Liked: 35
Which one of the JKP screens is better for a room with some ambient light? My room has a light colored ceiling that I can't paint a darker color....also heard they were coming out with a new one with 1.3 gain.
TL5 is online now
post #30 of 109 Old 07-25-2013, 11:12 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 2962
I have a sample of the new 1.3 coming soon in fact. For a room with some ambient light, the .9 gain might be your best choice, depending on your projector and screen size.
Reply Screens
Mitsubishi Hc7800d Projector Full Hd 3d Projector
