What Companies Build Affordable Custom Sized Screens? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-10-2013, 06:16 PM - Thread Starter
AJ~
AJ~'s Avatar
The title says it all.
The key word is "affordable," since I know that there are companies that will do custom sized screens for the over $1,000 price range. I can't afford those companies, and need to keep it under $500.
Suggestions?
AJ~ is offline
post #2 of 4 Old 04-10-2013, 07:07 PM
noah katz's Avatar
Quoted: 1107 Post(s)
Liked: 387
Dalite will make any size you want; price is that of the next biggest (widest I guess) standard size.
Noah
noah katz is offline
post #3 of 4 Old 04-11-2013, 12:56 AM
BobL's Avatar
Liked: 58
I am not sure what type of screen you are considering but with exception of a pull down screen I don't think you'll find any decent custom screen in your price range. You might want to consider making your own frame and buying a good screen material.
BobL is offline
post #4 of 4 Old 04-11-2013, 01:23 PM
adude's Avatar
Quoted: 50 Post(s)
Some members have got it from www.jamestownhometheaterscreen.com
pdoherty972 likes this.
adude is offline
Reply Screens
