Recommendations for Inexpensive Motorized ~100" Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-12-2013, 08:07 PM - Thread Starter
95CameronHawk's Avatar
I am purchasing my first projector to replace a DLP TV that is going through the last phases of it's life. Unfortunately I've left little in my budget to purchase a screen, so I am looking to purchasing a screen with the knowledge that I will be replacing it with a much better one at a later time. (I would rather not spend that time watching the projector without a screen).
My requirements for this are:
  • motorized
  • maximum external width of 90 inches - this only matters for the section that drops down including the screen, but would also need to include the bar/weight at the bottom - Also assumes that the distance from the screen to the edge of the casing is no more than 3 inches. If it is greater, than the size of the screen would need to be smaller (in my placement, only the left side matters)
  • less than $1000
  • acoustically transparent
I would love to hear some recommendations...
Thanks, really appreciate your help!
Edited to add the acoustically transparent requirement. This is really is a nice to have and not a requirement, but definitely would give me an awesome option to have a larger screen than my space would allow for and easier to find a pre-built size
95CameronHawk is offline
post #2 of 6 Old 04-13-2013, 01:13 PM
old corps's Avatar
Quoted: 157 Post(s)
Liked: 87
http://www.amazon.com/FAVI-HD-100-16-100-Inch-Projector/dp/B0017S37IG/ref=sr_1_4?ie=UTF8&qid=1365880226&sr=8-4&keywords=favi+projector+screen+16+9http://www.amazon.com/FAVI-HD-100-16-100-Inch-Projector/dp/B0017S37IG/ref=sr_1_4?ie=UTF8&qid=1365880226&sr=8-4&keywords=favi+projector+screen+16+9
Is this less than $1K enough?
I've been using the 120" model for 2 1/2 years and have been very happy with it. Never had any wrinkles or waves and operates perfectly. If it died I'd get another. JMHO
Ed
old corps is offline
post #3 of 6 Old 04-13-2013, 02:05 PM - Thread Starter
Thanks a bunch for the input, I've seen a couple other people on this forum using the FAVI screens. That's significantly cheaper than the one that I saw on Magnolia's site.
Out of curiousity, while this isn't a requirement, is this screen capable of putting speakers behind it? Or will that cause sound degradation?
Alternatively, do you happen to know any acoustically transparent options?
post #4 of 6 Old 04-13-2013, 03:02 PM
old corps's Avatar
Quoted: 157 Post(s)
Liked: 87
Sorry but no it's not an AT screen and I'm sure your sound would probably be degraded if you have to place your speakers behind it. Fortunately, I don't need to do that. Hopefully another forum member can suggest a decent budget screen that's AT.
Best of luck!
Ed
post #5 of 6 Old 04-13-2013, 03:06 PM - Thread Starter
Thanks I really appreciate your help with this... And advice. I'll definitely keep this option up as available. Just would be awesome if I could put speakers behind the screen.
Sorry for the evolving requirements. Edited the initial posting to include this
post #6 of 6 Old 04-13-2013, 04:18 PM - Thread Starter
Based on viewing other postings on this forum and looking online, the best I have found thus far that meets my needs is:
Elite Screen Electric 125 with the AcousticPro1080P2 screen ( http://www.amazon.com/Elite-Screens-ELECTRIC125H-A1080P2-Spectrum-Projection/dp/B0093E81FA/ref=sr_1_1?s=electronics&ie=UTF8&qid=1365888890&sr=1-1&keywords=ELECTRIC125H-A1080P2 ).
It doesn't fit into my dimensions, but I have found a way to make it work with the larger dimensions.
Based on the reviews I've seen from amazon and this forum it seems like a decent screen, but does any one have any better ideas?
Thanks!!
Reply Screens
