Highest gain AT screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-13-2013, 04:37 PM - Thread Starter
RapalloAV's Avatar
Quoted: 1625 Post(s)
Liked: 472
Is still a 1.12 gain AT screen the highest you can get?
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #2 of 7 Old 04-13-2013, 07:03 PM
BobL's Avatar
Liked: 58
Stewart has a 2.0 gain and others between 1 and 2 gain.
BobL is offline
post #3 of 7 Old 04-13-2013, 07:58 PM - Thread Starter
RapalloAV's Avatar
Liked: 472
These are perforated screens not woven correct?
Murray Thompson
X Owner RapalloAV
post #4 of 7 Old 04-14-2013, 05:02 AM
BobL's Avatar
Liked: 58
Yes, they are perforated.  There are some tradeoffs between perforated and woven but both can be exceptionally good.  Picture quality I like the perforated better if not sitting too close to see the perforations and you can get a screen material for your room conditions with a perforated screen.  The down side of a perforated screen is speaker placement, it is usually best to keep the speakers ~12" behind the screen and a little EQ to boost the high frequencies is needed.  The EQ is not a big deal and Stewart ships an EQ with the screen.  However, most of the time it is not needed as many of todays processors can do the EQ.
As with any screen you have to decide which works best for a given application.
BobL is offline
post #5 of 7 Old 04-14-2013, 05:51 AM
airscapes's Avatar
Quoted: 390 Post(s)
Liked: 307
And the kicker is.. WITHOUT seeing any of your choices in your room or even at all! rolleyes.gif
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #6 of 7 Old 04-14-2013, 06:25 PM - Thread Starter
RapalloAV's Avatar
Liked: 472
Don't think I can use a perforated screen then as there is no way I can get 12" clearance between the front of my speakers and the back of the screen.
Murray Thompson
X Owner RapalloAV
post #7 of 7 Old 04-14-2013, 10:29 PM
BobL's Avatar
Liked: 58
You can by with a little less like 6-8" but if you are looking for less than that woven is a better choice, you just need a brighter projector:-)
BobL is offline
Reply Screens
