Hang OR roll a projector screen ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-16-2013, 01:16 PM - Thread Starter
Noalkain's Avatar
Hi,
Should I let a projector screen hang or should I roll it back into the case when I am finish ?
Which way will keep a better screen quality ? (less screen waving etc...)
Thanks !
Noalkain is offline
post #2 of 7 Old 04-16-2013, 01:26 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Please explain your question, I don't understand what you are asking.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 7 Old 04-16-2013, 01:29 PM - Thread Starter
Noalkain's Avatar
Noalkain is offline
post #4 of 7 Old 04-16-2013, 02:25 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
I always roll mine up as it blocks the exit to the room.
The waves can be caused by the roller sagging so I am guessing letting it hang could put a little more strain on the roller but either way it will be the same amount of weight..
Doug
post #5 of 7 Old 04-18-2013, 12:26 PM
Mike Garrett's Avatar
Quoted: 5613 Post(s)
Liked: 3599
Originally Posted by Noalkain View Post
Hi,
Thanks !
Just be carefull rolling up the screen. Make sure there are no bugs on it. You would be surprised at how many screens get messed up from a squashed bug. smile.gif
mjgarrett100@gmail.com
Mike Garrett is online now
post #6 of 7 Old 04-18-2013, 12:53 PM
m Robinson's Avatar
Let your screen hang as much as possible. The more a screen hangs, the flatter it will be.
Our screens last much longer when they are used frequently and allowed to hang for extended periods. I'm pretty sure that holds true for most tab-tensioned screens. It is certainly true for Stewart Filmscreen Rollers.
Mark Robinson
Vice President of Technology
Stewart Filmscreen
m Robinson is offline
post #7 of 7 Old 04-18-2013, 07:43 PM - Thread Starter
Noalkain's Avatar
Noalkain is offline
Reply Screens
