120 inch grey screen with deep drop? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-16-2013, 08:50 PM - Thread Starter
sjess's Avatar
Liked: 26
Help! I'm looking for a specific kind of screen.
Ideally I want a 100 to 120 inch motorized screen I can ceiling mount, that is a high contrast grey material, and has at least 6 inches of black at the top of the screen so it will fall below the ceiling mounted center speaker.
I know there's the Elite Cinetension2 screen for about 1g, but I can't really afford that.
I can find screens under $500 that have most, but not all my needs. Maybe I need to compromise something.
Does anyone know of any options to have it all! Any help is appreciated.
sjess is offline
post #2 of 3 Old 04-16-2013, 09:13 PM
saskroadie's Avatar
I had an Elune vision screen from eastporters in a 106" size and a gain of 1.8 that had over 13" of black drop on the top of the screen. I wasn't real happy with the hotspotting but it might fit your needs with a correctly mounted projector. Though it's not listed on the website, I'm sure you can get the size you want....
http://www.eastporters.com/estore/cart.php?target=product&product_id=257&category_id=34
saskroadie is offline
post #3 of 3 Old 04-18-2013, 02:14 PM - Thread Starter
sjess's Avatar
Liked: 26
Thank you, I think that's going to work. Now to find out if I can fit 120" or if I need to be a bit more conservative and go with 106".
sjess is offline
Reply Screens
