da lite model b with csr high power screen have waves. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-18-2013, 07:43 PM - Thread Starter
squall12's Avatar
Hi guy,
My da lite model b with csr function that is using high power screen starting to have waves on it, so should i contact da lite for replacement? as i know high power screen is not effected by waves but in long term using it should i be worry? Thanks
squall12 is offline
post #2 of 5 Old 04-18-2013, 09:40 PM
BobL's Avatar
Liked: 58
ALL non-tensioned pull downs eventually develop waves.  However, the waves on a HP is typically not that noticeable with viewing material compared to some other materials.  If you are noticing the waves with viewing material on the HP it might be worth giving Da-lite a call.
BobL is offline
post #3 of 5 Old 04-18-2013, 10:50 PM - Thread Starter
squall12's Avatar
So far did not notice the waves during movie viewing but will i be seeing waves in near future?
squall12 is offline
post #4 of 5 Old 04-19-2013, 03:06 AM
BobL's Avatar
Liked: 58
You might if you look for them or on large bright areas of mostly a solid color, like shots of the sky or an icy/ snowy landscape.  But, most of the time you will not notice with that screen.
BobL is offline
post #5 of 5 Old 04-19-2013, 05:45 AM - Thread Starter
squall12's Avatar
ok Thanks BobL.
squall12 is offline
Reply Screens
