Screen to fit room and application - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-22-2013, 08:37 PM - Thread Starter
forevernewb's Avatar
Long time browser, first time writer,
I have a room that is 18' by 12' with the potential projector (Sony VPL HW50ES) about 12' ft back (ceiling mounted). Planning on a 100inch screen.
I will use the projector for 60% TV, 20% movie, 10% games, 10% friends over watching sports (someone check my math)
Plan on painting room a darker red or (insert suggestion).
There are two basement windows (1' x 2') at the rear of the room which will have cellular shades installed on, I'm thinking this won't be a big deal for ambient light, although this is my first projector and maybe I am woefully uninformed
I've been reading a bit and like the idea of the snomatte 100 but I'm not sure if it even exists anymore, as I see a lot of studio tek 100 coming back from google when I do a search, but can't really find anyone selling it.
I don't like the idea of having a screen with a tremendous amount of gain, as ambient light shouldn't be much of an issue.
I'd like to spend somewhere between $800-$1500 if the price justifies the results.
Any suggestions?
Matt
forevernewb is offline
post #2 of 5 Old 04-22-2013, 08:38 PM - Thread Starter
100 inch 16x9
post #3 of 5 Old 04-28-2013, 09:48 AM - Thread Starter
Perhaps just a link of where to start?
Matt
post #4 of 5 Old 04-28-2013, 02:29 PM
BobL's Avatar
Liked: 58
I wouldn't use a Studiotek 100 which is basically the same as a Snomatte 100.  It sounds like your room although dark is not quite that proverbial black bat cave which real makes a Studiotek 100 a great choice.  It is also out of your price range by a fair amount. Since it seems like you'd like to get as close to a reference material I'd look at Stewart Cima models the Tiburon and Neve are exceptionally good for the price.   The Joe Kane (HD Progressive) screens by Da-lite might be found in your price range with some discount.  The Stewart and Da-lite would be my top choice but are at the higher range of your budget.
 At the lower range of your budget I'd look at Seymour-Screen Excellence 103" with their Radiant White 1.3 material.  IMHO, since you a planning on a decent projector don't go scheap on the screen, get the Stewart or Da-Lite.  You will upgrade your projector many times before you ever consider upgrading your screen.  A good screen will last a long time.
forevernewb likes this.
BobL is offline
post #5 of 5 Old 04-28-2013, 09:03 PM - Thread Starter
Thank you for the guidance. Thats just what I needed.
Reply Screens
