Is an Acoustically Transparent screen necessary? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-29-2013, 03:22 PM - Thread Starter
PanicRGH's Avatar
Hello,
I am looking for a motorised pull down screen to pull down over my current TV/Speaker setup,
I have a very small area to work with before i get my dedicated space in a few years.
as my speakers would be behind the screen i understand that it would be best to have an acoustically transparent screen, but as AT Pull down screens are expensive and need to be tensioned i dont really want to pay alot of money for a smaller screen size.
I was wondering if getting a normal screen that does not have a AT material affect the audio quality?
i am no audiophile so i do not care that i am not getting the best possible experience?
but i also like things being good, so would a non AT screen still be able to pass through sound from the speakers behind?
is there a big difference or noticeable different in the material?
- Callum
PanicRGH is offline
post #2 of 5 Old 04-29-2013, 04:04 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
No.
The screen is a sheet of vinyl and sound does not go through it. Sound would come around it so you will loose the highs and vocals. Alter the placement of speakers, get smaller ones or a smaller screen.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 5 Old 04-29-2013, 08:04 PM
Quoted: 3265 Post(s)
Liked: 2751
Hang a vinyl shower curtain in front of your speakers, if you like what you hear a non AT screen should work just fine.
post #4 of 5 Old 04-30-2013, 02:15 AM
timhet's Avatar
The other option is buying smaller speakers such as bookshelves that fit under the screen.
timhet is offline
post #5 of 5 Old 05-02-2013, 11:45 AM
Mike Garrett's Avatar
Quoted: 5610 Post(s)
Liked: 3592
Thanks for the laugh, Big. smile.gif That would be a little better than leaving the speakers in the boxes they came in. smile.gif
mjgarrett100@gmail.com
Mike Garrett is online now
Reply Screens
