how to fix wavy lines on screen bottom sections - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-30-2013, 12:31 PM - Thread Starter
fluke440's Avatar
Greetings,
I was wondering if you had encountered issues with wavy lines with elite screens? It has been hung for a while
but just recently started to notice wavy lines at the bottom. More visible when watching programming with scrolling
text like espn, etc. Movies look ok...
Anyways, its a pull down screen. I was wondering if you had seen or experienced any fixes with velcro, as I can leave the
screen down and "attach it" to the wall etc..
I guess I'm just looking for suggestions?
JC
fluke440 is offline
post #2 of 3 Old 04-30-2013, 01:34 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Do a forum search "Waves" or Screen Waves" or Elite Waves.. you will find lots of people with the problem but there is no fix other than replace the screen with a tab tensioned screen..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 3 Old 04-30-2013, 02:55 PM - Thread Starter
fluke440's Avatar
fluke440 is offline
Reply Screens
