Can you live with screen waves? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-02-2013, 09:30 AM - Thread Starter
PanicRGH's Avatar
Hello,
im looking at getting a projector screen to pull down over my current TV/Speaker setup.
I dont have very much space at the moment before i get my dedicated space in a few years.
I found a 84" screen that just fits into the area i have to work with but i was told i should get a tab tensioned screen to avoid getting waves in the screen.
When i looked at some tansioned screens this made the case length longer meaning i could only fit a 73" screen.
As i only have a small area i would like the biggest screen possible, so if i get the 84" screen and get some waves is it easy to deal with?
Does it distract you/ get annoying or anything like that?
How long does a screen take to get these waves?
- Panic
PanicRGH is offline
post #2 of 4 Old 05-02-2013, 12:02 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4132 Post(s)
Liked: 4220
Waves do get annoying. Get a Da - Lite High Power screen - it does not need tensioning. Electric or manual pull down.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #3 of 4 Old 05-02-2013, 01:11 PM - Thread Starter
PanicRGH's Avatar
Thanks for the reply,
where do the waves occur? is it at the bottom?
If i am watching a 2.35:1 etc movie would i not see the waves?
PanicRGH is offline
post #4 of 4 Old 05-02-2013, 03:02 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4220
Probably the edges. But generally, a screen company like Da - Lite won't sell a manual or electric screen with material that will do that without it being tensioned to begin with. The materials in the non tensioned screens they sell ( like the High Power material ) tend to be stiffer and not wrinkle or have waves.
Reply Screens
