Please help me to choose - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-08-2013, 02:31 AM - Thread Starter
cemo62's Avatar
Quoted: 49 Post(s)
Hello
In my country we dont have much screen companies. I have only 2 choices. I would like to ask you will I have a problem with this situation about fL in the pic with elite screen?
fL with elite 1.1 white screen 24fL AND its cheaper than grandview.
fL with grandview 1.0 white screen 21fL
Room has dark grey walls and ceiling. Projector is sony HW50ES and viewing distance from screen to my eyes is 12 feet.
1st situation:
and 2nd situation with grandview
Kind Regards
cemo62 is offline
post #2 of 6 Old 05-08-2013, 08:18 AM
airscapes's Avatar
Quoted: 354 Post(s)
Liked: 285
you are way above the 14-16 fl that is the rule of thumb for a black room. I would not worry about 1 vs 1.1 but more about which screen has the most complaints as for quality here in the forum. Then buy the one with the least!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 6 Old 05-08-2013, 12:05 PM - Thread Starter
cemo62's Avatar
Quoted: 49 Post(s)
maybe these numbers are for high lamp mode, m I right? will i have problem with 23-24 fl? may I able to down the brightness?
cemo62 is offline
post #4 of 6 Old 05-08-2013, 12:32 PM
airscapes's Avatar
Quoted: 354 Post(s)
Liked: 285
I use a dalite HP screen and like it bright, 24fl is not a problem for me.
Doug
post #5 of 6 Old 05-08-2013, 12:59 PM
Mike Garrett's Avatar
Quoted: 5658 Post(s)
Liked: 3619
1.0 to 1.1 does not make a lot of difference. So I would go with the screen that had the smoothest surface. I do not know how smooth a Grandview is, so I could not recommend one over the other. Besides, I would not be surprised if the gain was not the same.
mjgarrett100@gmail.com
Mike Garrett is offline
post #6 of 6 Old 05-08-2013, 02:47 PM - Thread Starter
cemo62's Avatar
Quoted: 49 Post(s)
Thank you brother, i live in turkey we dont have many screens here. My only dubt is will i have problem with 24fL on my 106inch fixed frame screen? my room has dark grey walls and ceiling. The projectorcentral calculator shows to me it ll be 24fL
cemo62 is offline
Reply Screens
