Is Seymour the only screen company that can build manual masking panels for their screens? - AVS Forum | Home Theater Discussions And Reviews
Old 05-15-2013, 08:37 PM - Thread Starter
Plasticfish's Avatar
I am looking to buy a scope screen and am interested in masking. I know there are power masking systems from Carada and others, but they are several thousand dollars....nice no doubt, but pricey. I see that Seymour will build CIH panels for a few hundred bucks using a magnet system. Sure I'll have to put 'em up and take them down myself, but for a fraction of the cost, I think it's a great option for me. I'm looking at their non-AT screen (glacier white, I think it's called), but I am a bit concerned that I might need a bit higher gain screen considering my planned screen size. So....here's my question: are there other options out there for me? Do other companies offer a similarly priced manual masking system, but with a few more options for a higher gain screen?
Plasticfish is offline
Old 05-17-2013, 02:55 PM
Jive Turkey's Avatar
Quoted: 216 Post(s)
Liked: 136
There's always DIY. Mine has been in operation going on four years now and still does the job wonderfully.
http://www.avsforum.com/t/1169586/my-latest-masking-trial/0_50
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is online now
Old 05-17-2013, 04:25 PM - Thread Starter
Nice Jive Turkey...looks great. Far too complicated for me though. Not very handy.
Old 05-19-2013, 09:21 AM
Quoted: 216 Post(s)
Liked: 136
I'm not the handiest of folks myself. Kind of a Klutz, actually. You should have seen some of the bonehead mistakes I made yesterday just trying to do some house painting!
The keys to this working for me, both for effect and finances, was knowing that I wouldn't be satisfied without masking, and paying a signmaker a few dollars to properly put the masking material on the panels. I first tried doing velvet on them with contact cement, and what a mess I made of that! Plus, it's hard to get a crisp edge with velvet. The Protostar product left a very straight edge which makes a lot of difference at the horizontal masking line on the screen.
Keep researching and find what'll work for you one way or the other. Masking makes a lot of difference in the enjoyment level, imho.
See ya. Dave
