150" 16:9 vs 140" 2.35 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-26-2013, 07:40 AM - Thread Starter
gex598's Avatar
My AE4000 came yesterday and I set it up to project on the wall. I was planning on going with a 140" 2.35 screen but after seeing the projector zoomed out to 150" on 16:9 I was pretty amazed! Both screen sizes are the same width MOL its just the height difference. Going with the 16:9 I still get the same 2.35 image size so is it a no brainer?
gex598 is offline
post #2 of 6 Old 05-26-2013, 01:09 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
That is going to be one dim image.. calculator has it at 7fl once the lamp ages a bit it may be unwatchable.. unless you getting an Dalite HP.. good luck
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 6 Old 05-26-2013, 05:09 PM - Thread Starter
gex598's Avatar
The screen I am looking at is a 1.2 gain. I'll me mounting the projector at around 15 feet and using the max zoom. The I checked the calculator on projector central and it shows 14fl? What is the number I should be shooting for?
gex598 is offline
post #4 of 6 Old 05-26-2013, 08:40 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
14-16 but as the lamp get 300-500 hours on it, it can loose as much as 25% of it's brightness or more. Not to mention if you calibrate the projector you will not hit that light output with a new lamp. The calculator uses manufacture light output specs which are normally inflated.. Just something to keep in mind with going really big with a low or mid-range HT projector.
Doug
post #5 of 6 Old 07-22-2013, 03:28 PM
yourtoys7's Avatar
Where did you get AE4000, is it new or used?
EluneVision 106" Reference Studio 4K Tab-tensioned - 1.0 Gain, Benq 1070, psb T6, Rotel, OPPO, Velodine (Now),
135" AT screen, JVC-X35, 3x RF82, 3x Emotiva XPA100, Velodine, Rotel, OPPO (Sold with house).
yourtoys7 is offline
post #6 of 6 Old 07-22-2013, 11:10 PM
Crabalocker's Avatar
Quoted: 182 Post(s)
Liked: 122
If the Panny is as bright as my older Epson's (8500Ub, 8350) no worries on a screen that big. I run a 153" and it looks great. You may have to change the bulb a bit sooner than a person running a 100" screen but, for me anyhow, worth the cost for that cinematic experience! Bulb quality control more of a factor than screen size. I had bulbs go at 800 hours and others go at 2000.
If I were to do it again, I would go 2.35:1 though.
Good luck and enjoy!
Crabalocker is offline
Reply Screens
