Stewart StudioTek 130 vs StudioTek 100??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 05-27-2013, 02:20 AM - Thread Starter
mankite's Avatar
Quoted: 76 Post(s)
Liked: 61
Just trying to get some opinions from people who have seen both or better yet compared both. I currently have a 100" 16X9 StudioTek 130 G3 screen. Just wondering what differences I would notice switching to the StudioTek 100.
Mankite
mankite is offline
post #2 of 13 Old 05-28-2013, 08:51 AM
Mike Garrett's Avatar
Quoted: 5562 Post(s)
Liked: 3542
What projector are you using? If your room has really good light control and your projector has enough lumens, the 100 will provide a better image.
mjgarrett100@gmail.com
Mike Garrett is offline
post #3 of 13 Old 05-28-2013, 11:57 AM - Thread Starter
mankite's Avatar
Quoted: 76 Post(s)
Liked: 61
JVC 990. It does have good light control.
Mankite
mankite is offline
post #4 of 13 Old 05-30-2013, 12:34 PM
Pete's Avatar
Quoted: 219 Post(s)
Liked: 79
Unity gain screens like the StudioTek 100 or Da-Lite Progressive-Infinity will not exhibit the "sparklies" that screens with gain tend to have. But you not only need ambient light control, your projector must also have adequate brightness for the image size contemplated. LCOS projectors are somewhat light-challenged and that means if used with a unity gain screen the image size will need to be modest.
Pete is offline
post #5 of 13 Old 05-30-2013, 01:30 PM - Thread Starter
mankite's Avatar
Quoted: 76 Post(s)
Liked: 61
I ordered a light meter from amazon. Guess the first step it to see what my projector is capable of in my room.
Mankite
mankite is offline
post #6 of 13 Old 05-30-2013, 02:02 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
I was going to mention this too. I seem to be more sensitive to the "sparklies" than I used to be. You can request a sample of the 100 to compare.
I have an almost identical screen to what you have and use a very similar JVC projector. My room has medium colored walls and there is light spread all over them (worse on ceiling). It will just get worse with the 100. I don't have any issues with viewing angle, brightness shifts, etc.--just the sparkles.
B.
Brian B is offline
post #7 of 13 Old 05-30-2013, 05:04 PM - Thread Starter
mankite's Avatar
Quoted: 76 Post(s)
Liked: 61
I don't think I have any issues with my current screen as it is by all means the reference standard. I'm just curious about the 100 material. My ceiling is flat black and walls are a flat chocolate. I can always add some protostar light flock material to the walls and ceiling a couple feet out from the screen if light spilling onto the walls and ceiling became an issue. First things first I think I should measure the light output of my projector to the screen.
Mankite
mankite is offline
post #8 of 13 Old 07-09-2014, 10:00 PM
cardoski's Avatar
Quoted: 1170 Post(s)
Liked: 1133
I am considering the 100 and the 130, I have an Elunevison 4k 1.0 reference screen with a JVC X500R. The screen performs very well, disappears. But I want a bit bigger screen, currently 115in and I hear so much about the Stewart screens. Curious if you ever did change to the 100?
It's always in the last place you look.
cardoski is online now
post #9 of 13 Old 07-10-2014, 09:32 AM
DavidHir's Avatar
Quoted: 1702 Post(s)
Liked: 1320
I had tried out the HD Pro 1.1 and 0.9 and both exhibited sparkles, although much fewer on the 0.9 and most would not find it objectionable. I now have the Stewart StudioTek 100 and it's overall superior to the other two screens, but you need a black hole for it (which I have). The ST100 has notably better off-axis viewing too.
As far as brightness, I'm viewing on 2:35 screen at 108" wide with my JVC RS4810 iris at -3 with just 450 hours on the lamp. I'm at 11.8 ftL right now which is actually brighter than I probably prefer, so I should be good for a while with this lamp. With 16:9 content, I'm at -8 with 12.3 ftL.
DavidHir is offline
post #10 of 13 Old 07-10-2014, 05:52 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3036 Post(s)
Liked: 2967
With the StudioTek 130 G3 ( which I have ) you won't light up your room as much, as with the StudioTek 100. You really do need a " black hole " of a room to get the best out of the 100. I virtually never see artifacts with my StudioTek 130, except rarely in the brightest of scenes - and I'm watching a 3 chip DLP on a 128" diagonal 2.35:1 screen from 12 1/2 feet.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #11 of 13 Old 07-10-2014, 09:16 PM
DavidHir's Avatar
Liked: 1320
Your ST130 G3 has to be pretty darn bright though.
When I had the HD Pro 1.1 (which Jeff Meier measured at a 1.18 gain on-axis) it was very evident just how much brighter it was compared to the HD Pro 0.9 and ST100. I imagine I could have stretched out my lamp for a while on it, but the sparkles were too strong from my taste. I also found even after pro calibration on the 1.1 the color was not quite as good compared to the other two screens which are more color neutral.
DavidHir is offline
post #12 of 13 Old 07-11-2014, 05:24 AM - Thread Starter
mankite's Avatar
Quoted: 76 Post(s)
Liked: 61
I haven't done the switch yet and not sure I will. Off axis viewing isn't a concern in my theater as it's only 11 feet wide. I'm sure the ST100 is better in some areas then the ST130 but nothing about the ST130 annoys me. Reason I started this thread was because I have a 100" diagonal 16X9 screen with the 3.5" frame and was thinking of going to a 106" screen with the thinner frame they offer. I still may go bigger on the screen at some point but it would depend on what projector I have at that time which material I would go with. My projector sits 19' from screen and if I have something along the lines of a Jvc then I would stick with the ST130. If I have something with more brightness like the Sony VW600 4K machine then a decision would be in order.
Mankite
mankite is offline
post #13 of 13 Old 07-17-2014, 07:22 PM
Liked: 0
same to me,My projector sits 19' from screen and if I have something along the lines of a Jvc then I would stick with the ST130. If I have something with more brightness [IMG]http://*******/Ffva1z[/IMG][IMG]http://*******/Ffva1z[/IMG]like the Sony VW600 4K machine then a decision would be in order.
earniandrig is offline
Reply Screens
