Help me choose between these two projector screens: SI SolarHD 4K or Carada Criterion BW - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 05-29-2013, 10:02 AM - Thread Starter
DrZaus's Avatar
Hello everyone, please help me decide between two of these screens:
Carada Critereon 160" 2.35:1 cinemascope format , claimed 1.4 gain briliant white or Screen innovations Perfomance/Reference series 160" 2:35:1 cinemascope format, SolarHD 4K model 1.3 Gain
The projector will be Sony HW50ES with (anamorphic lens - still researching) mounting distance will be between 16 to 18 feet.
Room dimensions 16.75 feet width 23 feet length,10 foot ceiling height, Black ceiling , Dark gray wall paint.
My question projector screen is this too big for this room? I want to mainly use movies and ocassional movies from Satilite tv, no gaming at all.. Will I be running on high mode for a screen this size? or should I stick to a 133" version of any screen, I will need to pick-up a Darblet for clarity or un-necessary?
Please help me decide...
All comments are appreciated in advance..
DrZaus is offline
post #2 of 13 Old 05-30-2013, 08:01 AM
Mike Garrett's Avatar
Quoted: 5550 Post(s)
Liked: 3539
With a 160" diagonal 2.35 screen, you should be closer to the back of the room. I would use the 19' max throw of the projector. This is to help with the pincushion. I sent you a PM.
mjgarrett100@gmail.com
Mike Garrett is online now
post #3 of 13 Old 05-30-2013, 09:31 PM
ahkim's Avatar
I'm trying to decide between these two screens as well. I'd be curious what you've found out thus far or if you made a decision. I had a nice chat with Mike earlier today and I thought he said that Solar4K has more gain than the Carada BW.
ahkim is offline
post #4 of 13 Old 05-30-2013, 10:16 PM - Thread Starter
DrZaus's Avatar
I'm going with the SolarHD 4k.. but contemplating on screen size.. SI only make 133" and 160" nothing in the middle.. and too may choice on anamorphic lens's.. Need to weight your option if you want to do 3D or not..
DrZaus is offline
post #5 of 13 Old 05-31-2013, 03:59 AM
kingajit's Avatar
Dear Zauss,
I have compared the SI Innovations, Carada BW & CCW and the DNP.
The best value for money screen is the Carada BW & CCW. Once you reference the price of the Carada with the image you are getting then when you compare them against the expensive brands then there is no increase in performance as the cost increases. Between the same manufacturers if you compare the high gain to unity screens you will notice significant distortion and contrast and color accuracy issues!
It is extremely hard to decide between Carada BW and CCW as both are equally good.
Suggest order large samples and pay if required for the samples before you decide....cheers
kingajit is offline
post #6 of 13 Old 05-31-2013, 09:14 AM - Thread Starter
DrZaus's Avatar
King Ajit, Namaskar, I ordered the Carada sample for BW and it look like the color of beige or butter.. what is CCW ? As Mike mentioned before the Carada measured a lower gain than they advertise and the SolarHD 4K was right on or even more @ 1.37 gain. I found the pricing to be in the same ballpark.
DrZaus is offline
post #7 of 13 Old 05-31-2013, 10:31 AM
ahkim's Avatar
Originally Posted by kingajit View Post
Dear Zauss,
I just ordered the RS45 and will order either the Carada BW or SI Solar4K and was wondering if you can clarify what you wrote. Are you saying the extra cost for the SI Solar 4K is not worth the money over the Carada? Or are you referring to the more expensive screens beyond the SI?
I'm looking at either a 120 or 130" screen size. I prefer a bright image so the extra gain from the SI would be nice but not at the expense of quality (or price).
Also, who do you contact to get samples? I looked on Carada's webpage and didn't see anything about samples.
ahkim is offline
post #8 of 13 Old 05-31-2013, 12:24 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
I have a Carada BW 115" precision 2.40:1 screen and, while it is a 'good' screen, there are some differences in color accuracy between the lower cost (under a grand) screens and let's say the Studiotech 130. If I were to do it over again, i'd buy the 130 which doesn't push red and has some more gain to it. BTW, i am using a JVC RS20 with A-lens. And don't go for the elite screens: they push blue and are not considered 'reference' by any means. On the other hand, bang for the buck, the carada is still nice wink.gif
below is a comparison of a Carada BW (right) vs Elite (left) over my DIY screen I had a few years ago....hope this helps, and is slightly ON TOPIC....
AppleMark
KBMAN is offline
post #9 of 13 Old 06-01-2013, 12:54 AM - Thread Starter
DrZaus's Avatar
You have to call them and then send you the samples or you can email the your info to them.. They sent me samples. smile.gif
DrZaus is offline
post #10 of 13 Old 06-17-2013, 12:38 AM - Thread Starter
DrZaus's Avatar
Just pulled the plug and purchased the SI SolarHD 4k... 235:1 smile.gif , Spoke to Da-Lite for high power option and they said, the projector has to be on a table and eye level..or unless you going to mount on a stripper pole (long pole down from ceiling about 6 feet, don't even think about it..
DrZaus is offline
post #11 of 13 Old 05-18-2014, 08:24 PM
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
I like resurrecting threads on the exact topic rather than starting another. You get the backstory, other opinions, etc.
I'm comparing Carada and Screen Innovations. I can get the SI screen from a local A/V dealer, from whom I am getting a lot of other gear for my theater.
I'd be willing to spend a couple hundred more for about the same thing with the local dealer to get local support.
I'm considering:
-Carada BW criterion 110" 16:9 screen (1.4 gain but really 1.1 to 1.2 from what most say) - $901
-Screen Innovations Performance 16:9 Solar 4K 1.3 gain ($1299 + tax)
-Screen Innovations 16:9 Pure 4K 1.3 gain (haven't priced - I think this is wayyy out of my price range but I'm not sure- think it only comes with their zero edge frames)
So - what does it come down to? The EXACT same question the original poster (OP) had. Except before any arguments he said he was going with the SI screen.
Dr Zaus - Why did you pick the SI over the Carada? Was it performance, or something else? Sounds like you decided from the screen samples. What set them apart?
At this point if they were the same performance, I'd pick Carada. I won't pay $400 more to get it locally.
How about the Carada Criterion frame versus the SI Performance frame? How do they compare?
Hardware and System engineer. Enjoy theaters, automation, media and the outdoors.
Love the hobby, but always have to remember to keep family first!
"The Escape Pod" - First Theater Build
danielrg is offline
post #12 of 13 Old 01-30-2016, 01:03 PM
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
I'm considering:
Funny - I'm actually ready to buy my screen... 1.5 years later. And I am having the same dilemma. Then I find my own attempt to "resurrect" this thread... I'll try again, still think it's better than a new thread. But I'll try that next.
I have samples of the Carada CCW, and the Carada BW. I like the pop of the BW, but I don't like the red/yellow color casting. That turned me off from it. I suppose calibration could compensate but... I much preferred the color balance of the Carada CCW.
I also have a sample from SI of the Pure White 1.3. THAT is a a beautiful screen material. Great pop, but maintains excellent color accuracy, from what I can see. Just like the CCW color accuracy, but just brighter, no color cast.
I don't have a sample of the Solar 4K 1.3 gain material. I'm hoping the performance is similar to the Pure White 1.3. If it was, I'd get it.
1-I can get the CCW is about $700
2-Solar 4K screen is about $1300
3-Pure White 1.3 is about $2000
4-Stewart Studiotek 130 is about $2700
Anyone compared all these? Again I have #1 and #3 . Anyone compared #1 and #2 ? #2 is the sweet spot in price if I want the extra pop of 1.3 gain (which I think I do... but then there's the sparkles...)
danielrg is offline
post #13 of 13 Old 02-03-2016, 11:27 PM
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
I auditioned the StudioTek 130 today.
Brought my SI Pure White 1.3 and Carada CCW samples with me and the salesman held them up (we held them up for each other).
The CCW, by eye, seemed to match the color balance of the StudioTek really well. I couldn't see any differences. It was just dimmer (1.3 gain vs 1.0 gain). For the price, I like the Carada CCW a lot. The ST130 was exceptional.
The Pure White 1.3 was slightly dimmer than the ST130, and the color balance was bluish/cool in comparison, quite noticeable to both me and the salesman by naked eye.
I still haven't seen the Solar 4K. Rush hour and 30 minutes in the wrong direction and I decided to head to that dealer later.
danielrg is offline
Reply Screens
