Cleaning a screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-03-2013, 11:55 PM - Thread Starter
toddhbailey's Avatar
Hi All,
Over the years my dalite glass bead screen has collected a fair bit of dust/dirt and even a couple of latex paint splatters.
Whats the best way to clean the screen?
I've tried mild soap and water but it seems to only have made matters worse or at least no better.
thanks
toddhbailey is offline
post #2 of 5 Old 06-04-2013, 06:19 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Is this a large glass bead or the High Power screen?
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 5 Old 06-04-2013, 09:57 AM - Thread Starter
it's their "highpower" screen
post #4 of 5 Old 06-04-2013, 10:01 AM
same issue, I'm looking for something wide to wipe it off but so far without result.
gain3 is offline
post #5 of 5 Old 06-04-2013, 10:04 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Here are several threads on the process, I have done it more than once with great outcome. Please pay particular attention to my posts as the denatured alcohol works best but you need to buy traditional DA not the new green crap!
http://www.amazon.com/SUNNYSIDE-CORPORATION-83432-1-Quart-Denatured/dp/B000BZZ36K available in any hardware store.. NO SMOKING WHEN USEING THIS STUFF AND OPEN WINDOWS!
http://www.avsforum.com/t/1094109/da-lite-highpower-cleaning/0_100
http://www.avsforum.com/t/1450052/who-has-done-a-full-screen-wash-on-a-hi-power-2-8-methodology-happy-with-results/0_100
Doug
Reply Screens
