Projector Newbie Here - Can I put a 120" screen in this wall? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-05-2013, 11:37 AM - Thread Starter
ea5055's Avatar
Hello, and thanks in advance for the help. Looking to put a 120" screen here, motorized, 16:9 right below that bulkhead on the left. I'm attaching measurements.
This is going in an all-purpose room in the basement, but it will be for movie watching at night when the kids go to bed. I don't mind if the screen is a bit too close to the floor, as long as the projector can project the image properly. I have about 18 feet of distance from that wall to the opposite wall.
I'm looking at the BenQ W1070 which has a lens shift, but I cannot tell if the lens shift will be enough to avoid keystone correction when projected from the ceiling.
I appreciate any help! Thanks
Without measurements:
Can I put a 120" (diagonal, 16:9 ratio, electrical) projector screen here? See next picture for measurements
With measurements:
Can I put a 120" (diagonal, 16:9 ratio, electrical) projector screen here? See previous picture without measurements
ea5055 is offline
post #2 of 12 Old 06-05-2013, 12:08 PM
ivanhoek's Avatar
Liked: 24
Yes, you can put a 16:9 120" screen in there. I have that screen size and my overall dimensions are about 111" by 66". I would go with a fixed frame since it doesn't seem like you'll have anything behind the screen. Fixed frame screens are simpler and more reliable.. they can also be cheaper and provide a better picture in many cases due to the absence of waves or wrinkles that can sometimes appear on motorized screens, even the tensioned ones (if not higher end).
ivanhoek is offline
post #3 of 12 Old 06-05-2013, 12:21 PM
Crabalocker's Avatar
Quoted: 182 Post(s)
Liked: 122
You can do it but it might look a bit funny. You would have to have the screens motorized frame mounted under your bulk head as a motorized 120" screen will be around 118" wide (frame case). The viewable area would be approximately 10" below the bulk head and around 14" off the floor. My screen is also close to the floor and it looks rather good to me but mine is centered. Yours would look a bit unbalanced but workable...IMHO. Who knows, maybe it'll look great!
As for the projector? I'm not that familiar with that projector, not too sure about the lens shift of the W1070. It might hang a little low if the lens shift is not great.
If you can work it out, I'd go for it. Projectors are awesome! nothing like watching a movie on a large screen.
Good luck!
Crabalocker is offline
post #4 of 12 Old 06-05-2013, 02:52 PM
airscapes's Avatar
Quoted: 330 Post(s)
Liked: 276
Will you have room for speakers? AT (Acoustically transparent) will be needed if you are using in-walls behind the screen. AT will dive up the price and seating location is very important since you will see the weave of most fabrics if you sit closer than 12'
Here is a report on different screen fabrics, AT is after the regular but he heading looks to have been copy and pasted without changing it to say AT
http://accucalhd.com/documents/accucal_front_projection_screen_report.pdf
120" screen is 59" (plus boarder) x 105 (plus boarder) and the benq would need to be betweeen 10 and 13' back to get you to 120. I know the shift is not great, download the users manual and look at the install section, that should give you the data you need.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #5 of 12 Old 06-05-2013, 04:53 PM
Quoted: 182 Post(s)
Liked: 122
Little satellite speakers would work and you'd have room on the sides for them (and bottom for center). I had a cheap little polk system (RM8' system) and it filled my 25 x 27 room, and it sounded surprisingly big!
post #6 of 12 Old 06-08-2013, 05:57 AM - Thread Starter
ea5055's Avatar
That's a good idea, but how kid-friendly are fixed frames? Can they stand being touched and small objects thrown at it? smile.gif
ea5055 is offline
post #7 of 12 Old 06-08-2013, 06:00 AM - Thread Starter
ea5055's Avatar
Good luck!
Yeah, my wall is not ideal but I'm going to go for it anyway. Hopefully some low type seating like bean bag chairs will make it so that the screen being too close to the floor is not an issue.
ea5055 is offline
post #8 of 12 Old 06-08-2013, 06:05 AM - Thread Starter
ea5055's Avatar
The speakers I will put up are the Bose (yeah, yeah I know, but I got them 'free' with miles) acoustimass 10. I downloaded the BenQ Manual and sill can't figure out exactly the lens shift range. According to projector central is about 10% of the image height up and down from the center. So on a 120" diag with 60" vertical, I figure it's 6". I might be wrong here though. I think with that, plus a the mount I should be able to clear the 10" bulkhead and the screen case. I hope so anyway... I guess last resort would be to increase the mount length and have it hang lower. Any ideas? Thanks
ea5055 is offline
post #9 of 12 Old 06-08-2013, 06:06 AM - Thread Starter
ea5055's Avatar
I got the Bose acoustimass speakers, so hopefully they'll do the trick. Just need to find some nice cheap mounts for them. Bose's are too expensive.
ea5055 is offline
post #10 of 12 Old 06-08-2013, 09:27 AM
Quoted: 182 Post(s)
Liked: 122
The problem with a projector that has limited lens shift and your screen placement is the projector will have to hang really low in order to line up with the screen. This will compound the problem if the projector is behind the seating; heads will get in the way of lighting the screen. Maybe find a projector that has a better lens shift??? Maybe find a good deal on any left over Epson 5010's??
Having the screen closer to the floor is not all that bad. I like not having to angle my head and look up, I look straight ahead....works well, IMO.
As much as people make fun of Bose, they still sound pretty good and that is the most important part. Yes there are better speakers out there but all the Bose systems I've heard all sounded ....good. redface.gif
Oh yea.... you'll have to paint your screen wall (+ that little side wall) a flat dark colour, that bright yellow won't help. And make sure you get a tab tensioned electric.
post #11 of 12 Old 06-08-2013, 03:40 PM - Thread Starter
ea5055's Avatar
Thanks for the tips. I think a tab tensioned screen is out of my budget though.
You don't think I can clear the 10" bulkhead with a bit of vertical shift? Is there a calculator out there for that? Thanks
ea5055 is offline
post #12 of 12 Old 06-08-2013, 05:05 PM
Quoted: 182 Post(s)
Liked: 122
Reply Screens
