Help with screen for Sony VW1000ES - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-07-2013, 04:49 PM - Thread Starter
raded's Avatar
I am redoing a dedicated theater room in a house that was recently purchased. I have decided on 135" , 16:9 but cannot decide b/w the Stewart studiotech and snomat. This is a completely light controlled room. I will be painting the ceiling black this weekend as it currently tan. Otherwise the walls are dark brown. I am interested in opinions current and former owners of these two screens or those who have seen the actual screens. I'll be adding a horizontal carada masquerade to complete the room.
raded is offline
post #2 of 2 Old 06-10-2013, 05:14 PM
ivanhoek's Avatar
Liked: 24
The snomatt will work well at that screen size with your projector. It's a little large, but your projector is plenty bright.. the only caveat would be if you're doing 3D, then you might prefer the studiotek. I have a 120" studiotek and find that it does help a bit with 3D on my hw50es (less bright than your 1000es).
ivanhoek is offline
Reply Screens
