Case length (solved) - AVS Forum | Home Theater Discussions And Reviews
Old 06-08-2013, 02:19 PM - Thread Starter
Manglero's Avatar
i am looking for a 100"+ screen with a max case length 234cm some tips?
the Elite screens 100" M100XWH is 236cm and maby it's possible to remove the end cap and grind it to 234cm
found the answer --> ELITE SCREENS 12" Extended Wall/Ceiling Bracket set for VMAX/Spectrum/Manual max 34kg
Manglero is offline
