What screen and optimal size + mount - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-09-2013, 04:37 PM - Thread Starter
squigly1's Avatar
Hi,
Getting a Benq w1070 and banging my head against the wall over screen size. Room is 20ft long, 10.8ft wide, 7ft high. Originally thought 108" would be right. Got the below from the Benq site:
Am I right in that I have 7 inches top of screen (not including frame) to ceiling and since the projector is like 4.1" high the mount needs to be a tad less than 3 inches? Do they make a mount that small or should I be getting a smaller screen? With the 108" screen I was getting the Elunevision 4K Reference. Their next size down is 100". If I have to go smaller than 108" but not as small as 100" what size and what is a comparable brand and make? I'm in Canada so hopefully something I could find up here but not necessarily a dealbreaker. BTW, the Elunevison is like $1000.
squigly1 is offline
Reply Screens
