The official Falcon Screens acoustically transparent screen thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 144Likes
post #181 of 559 Old 05-01-2014, 06:10 PM
Hockeypucks's Avatar
Quoted: 12 Post(s)
Liked: 49
I ordered a sample from Rich, Seymour and Carls shearweave but I'm still framing my theater. I'm going with a floor to ceiling 16:9 screen to make the most out of my 7ft ceilings. I'm liking what I've read so far and feel I'll be going with Falcon as well. Here's an image shot on a concrete wall with a terrible beige stucco. I'm quite happy with the image quality so hopefully a white screen will look good.
snickers1 likes this.
Hockeypucks is offline
post #182 of 559 Old 05-18-2014, 08:12 AM
archiguy's Avatar
Quoted: 3412 Post(s)
Liked: 3274
Are the masking panels covered in black fabric? What kind / brand?
I'm getting to the point where I'm going to be covering the ceiling and walls around the screen in black fabric and thought it might be good to match it to the masking panels. Or not. I'm really not sure. But I do know I'm going to have to be making a lot of finish choices very soon, for better or worse. Drywall hanging in the theater room is starting Monday! Finally! After having the room rough framed now for 9 months...
archiguy is online now
post #183 of 559 Old 05-18-2014, 08:34 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
Yes they are covered in black acoustically transparent material, the inner edge of the masking panel is covered with the same velvet as the frame.
a screen using black Gom is always a great match.
snickers1 is offline
post #184 of 559 Old 05-22-2014, 12:24 AM
johnmi's Avatar
Hi All,
New to the forum, building my first HT. A very modest set-up compared to others, but never the less, something that will give us a lot of enjoyment. (I hope!) This is an interesting thread, I've read through all of it to see what everyone's input is on the different screen types. Jon at Seymour is sending me a sample of both the XD and UF material to check out up close, since my viewing distance will only be about 8-9ft. After reading this thread, it seems to me there are other choices for me to consider, (manufacturers) that offer just the material for DIY screens? I'm also interested in the new AT masking Snickers has mentioned above. I will be using 2:40.1 aspect ratio using the zoom method, so would like to mask to a 16:9 at times.
Can anyone suggest where I might get other samples to compare with the Seymour screen samples on their way?
John
johnmi is offline
post #185 of 559 Old 05-22-2014, 05:27 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
Originally Posted by johnmi View Post
Hi All,
John
John, just send me a pm with your address and we will be happy to send you out a sample of the Falcon material. We also offer our material for DIY.
post #186 of 559 Old 05-22-2014, 05:49 AM
johnmi's Avatar
Perfect Rich, PM sent and thanks.
johnmi is offline
post #187 of 559 Old 05-22-2014, 09:22 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Hi All,
John
Definitely get a Falcon screen sample, I know there was no way I could use the XD material at 9ft away. The Falcon screen material would be a perfect fit for you IMO. smile.gif
jbrown15 is offline
post #188 of 559 Old 05-22-2014, 09:52 AM
Quoted: 12 Post(s)
Liked: 49
I've ordered my screen and it's en route to my house now. Overall size is 140x80 for a 158" 16:9. I'll post pics when I can, still building theater but should be done in a few weeks.
post #189 of 559 Old 05-22-2014, 07:18 PM
johnmi's Avatar
Thanks for the info. Yea, Rich is sending me a sample. I was also concerned about seeing the patterns in the XD so was actually thinking the UF would be better for me. (despite its lower gain) Although, after reading this thead I've learned that the Falcon may do better than either of the others, so I'm really looking forward to checking out that sample when it arrives.
johnmi is offline
post #190 of 559 Old 05-23-2014, 11:18 AM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Johnmi I am in Nashville so if you ever want to come see a 161" wide Falcon screen you are welcome to come over.
hifiaudio2 is offline
post #191 of 559 Old 05-23-2014, 05:06 PM
johnmi's Avatar
HiFi audio, Thanks for the invite I may take you up on it. So far, I've heard nothing but good things about the Falcon screens. I'm in the building process, so no immediate rush to get any one thing in particular so I'm doing alot of research. There's so much to all of this, I can't even guess how many pages of specs I've read in the last few weeks! (between screens and all the other nec. equipment)
Thanks again for the offer, much appreciated.
John
johnmi is offline
post #192 of 559 Old 06-06-2014, 04:21 PM
archiguy's Avatar
Liked: 3274
Question for Rich or anyone who's bought the masking panels...
I'm going to have a 110" 'scope Falcon screen with Bronze Triads in the wall behind it. Are the masking panels completely acoustically transparent or will I need to have my receiver's Audyssey program re-calibrate the speakers for when the panels are deployed? Will the volume level for them have to be adjusted slightly upward to compensate for any acoustic damping the panels might inadvertently create? Would it make sense to have two different calibration points that would change (I'm assuming my receiver can do that), maybe with a macro command, when the aspect ratio was changed and that panels were added or removed?
Anybody tested for that?
post #193 of 559 Old 06-06-2014, 06:32 PM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
you will not need to recalarbrate your system to compensate for when you have the panels installed. In our testing they was only a .3db difference with the panels installed as apposed to without them installed.
this is assuming your entire speaker is covered by the panel.
post #194 of 559 Old 06-10-2014, 08:17 AM
archiguy's Avatar
Liked: 3274
You know, the edge of the masking panel might actually fall right down the middle of the L/R speakers. Is there a frame member on the sides that might cause an issue if that's the case?
post #195 of 559 Old 06-10-2014, 08:32 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
no the frame of the masking the panels is very thin only 1" wide
post #196 of 559 Old 06-10-2014, 11:36 AM
johnmi's Avatar
Hi Rich, I received the sample you sent me and it looks great. Just sent you a PM.
John
johnmi is offline
post #197 of 559 Old 06-10-2014, 11:46 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
John
Thanks John got it
post #198 of 559 Old 06-15-2014, 09:03 PM
johnmi's Avatar
AT screen material
Well after a lot of comparing, I've decided to go with the Falcon screen material from Rich.
At my seating distance of 9ft. it will be fine and much better than the others I checked out. (The XD and also the UF material) IMO, I found the gain to be very comparable to the XD material and noticeably higher gain than the UF material I tested against and a better PQ quality with the Falcon.
Now I just have to start thinking about building a good frame, not to mention the rest of the room!
johnmi is offline
post #199 of 559 Old 06-17-2014, 01:38 PM
Barrettmr's Avatar
Quoted: 105 Post(s)
Liked: 29
I have requested a sample as I am looking for a new AT screen (coming from a non AT fixed frame) and wanted to see if anyone was watching 3D on this Falcon fabric and if I should expect a different PQ compared to watching 3D on a non AT Screen?
Barrettmr is offline
post #200 of 559 Old 06-17-2014, 02:09 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Assuming a seating distance where the weave disappears, 3D will look identical, except a little dimmer assuming that your non AT screen had at least some gain.
johnmi likes this.
post #201 of 559 Old 06-17-2014, 05:17 PM
johnmi's Avatar
At 9ft, the Falcon screen material weave is not visible to me. This was one of two main concerns I had in choosing which material to use for our screen. Perhaps someone with better vision might see it closer? but even down to 6ft it looks good to us.
After many "tests" using different materials behind the 3 screen samples I was comparing, I concluded the gain of the Falcon was very comparable to the XD material. (Using ONLY our visual reference for comparison, no meters used) I studied the gain as best I could (again only from a visual reference) using different input signals, brightness settings and different movie scenes etc., since 3D is also a concern for me I really wanted to compare gain. I feel the Falcon was equally as bright as the XD and much brighter than the UF material. Secondly, I could clearly see the weave in the XD material at 9ft and even as close as about 5-6ft.
I'm in the process of building my first dedicated HT so I'm a newbie when it comes to HT screens. My testing is crude to say the least in comparison to technical methods of testing, but hopefully this will give a bit of useful info to others in the same boat as myself. IMO, the Falcon material beat the other two samples hands down. Thanks for all your help Rich!
BTW hifiaudio2, I've just read through your build thread, fantastic job and a beautiful outcome on your theater room. Congrats!
John
johnmi is offline
post #202 of 559 Old 06-17-2014, 05:38 PM
johnmi's Avatar
Hi Barrettmr,
I spent quite a bit of time deciding which material to use and just finally purchased Falcon material for a DIY AT screen. I can't say compared to a non-AT screen when it comes to 3D, but I can say that the Falcon material looked better than the other AT materials I compared it against. I "tested" three types (as I posted above) and the Falcon was the best looking PQ to me and I can't see the weave at 9ft. 3D is also important to us so I spent a lot of time comparing the gain as best I could. Again, I think the Falcon gain was as good or better than the other AT materials. Hope this helps.
John
johnmi is offline
post #203 of 559 Old 06-17-2014, 07:23 PM
Barrettmr's Avatar
Quoted: 105 Post(s)
Liked: 29
Hi Barrettmr,
John
Great thanks for the quick reply, that makes me feel much better, I have the Epson 5020UB which has a good amount to light power for 3d so it sounds like I would have a good experience with this screen, I'm going from a 106" diagonal HDTV screen to this 120" to 130" AT screen, my first row is about 14' back so I think it should be a good fit!
post #204 of 559 Old 06-18-2014, 03:52 PM
johnmi's Avatar
Great. I'm glad the bit of info I offered may help you out. When you get your sample, you'll see what I'm talking about. Do you have other sample types to compare against?
johnmi is offline
post #205 of 559 Old 06-18-2014, 05:40 PM
Barrettmr's Avatar
Quoted: 105 Post(s)
Liked: 29
Well I took a good look at all the info on the website and read all the reviews here and decided to order now without the samples... I need to complete my remodel in about 2 week and after speaking with Rich I felt good about going for it :-O
I'll post back once I am done and share my experience with my setup!
post #206 of 559 Old 06-18-2014, 08:06 PM
onyxbfly's Avatar
Quoted: 49 Post(s)
Hey Rich I see what you did there!!!! You, Sneaky Devil, LOL Thanks for taking care of my lady!!!
onyxbfly is offline
post #207 of 559 Old 06-18-2014, 08:13 PM
jbrown15's Avatar
Liked: 1993
I had screen sample from Seymour of both the XD material and the EN4K material and some from Elunevision 4K audioweave material, I bought my Falcon screen sight unseen and have been extremely happy with the picture and build quality of it. Rich has been awesome to deal with and its always nice to support a fellow AVS member with his start up venture into the screen market.
Next month I'm hosting a small speaker GTG with close to 20 forum members coming out, I can't wait to show off my Falcon screen!
Barrettmr and johnmi like this.
jbrown15 is offline
post #208 of 559 Old 06-18-2014, 09:12 PM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
Your very Welcome!! it was my pleasure she was so excited to get this done for you was very happy help.
enjoy
Rich
onyxbfly likes this.
post #209 of 559 Old 06-18-2014, 09:15 PM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
Hey i was not invited LOL!!!! Can't waite to hear about the event send me some pics
post #210 of 559 Old 06-18-2014, 09:16 PM
jbrown15's Avatar
Liked: 1993
Yes you were, I said you can fly out with my masking panels!...lol
jbrown15 is offline
Reply Screens
