Seymour XD Sizing question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-19-2013, 03:29 PM - Thread Starter
joechuan's Avatar
Hello everybody,
I need some advice as to which screen size to get 120" vs 130"
I have a completely light controlled environment (completely dark if needed) and...
Sony HW30ES projector
View distance 12-13ft
Screen is 3ft off floor
Seymour XD acoustically transparent screen.
Questions:
Should I get a 120 or 130" screen?
Can this projector be about 77 off the floor?
Thanks for your help in advance!
Joe
joechuan is offline
post #2 of 6 Old 06-19-2013, 10:10 PM
Mike Garrett's Avatar
Quoted: 5652 Post(s)
Liked: 3616
Originally Posted by joechuan View Post
Hello everybody,
Questions:
Joe
Are you talking diagonal or width? Also depends on throw distance, your room and how important 3D is to you. Yes you can mount the projector so that the lens is 77" above the floor as long as the image (using 120" diagonal 16:9) is not closer than 7" to the floor. smile.gif If you need so help, give us a call.
mjgarrett100@gmail.com
Mike Garrett is online now
post #3 of 6 Old 06-20-2013, 09:09 AM - Thread Starter
joechuan's Avatar
Mike,
Thanks for your reply. The throw distance is approx. 14 feet. 3D is not that important to me. I just want to optimize the 2d experience. When viewing from 12-13 feet would the 120" be sharper than the 130" screen and/or would the 130 be too overwhelming for a picture size?
Joe
joechuan is offline
post #4 of 6 Old 06-20-2013, 10:16 AM
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
Mike,
Joe
Joe,
If you already have the projector you are in luck as the absolute BEST way to determine if a given screen size will give you the immersion you desire and not be overwhelming is to either project on the wall if the wall is light colored enough or project on to a bed sheet! wink.gif
You can then experiment with various size screens and live with it for a bit and then you can make a really informed subjective decision! biggrin.gif
Obviously, if you do not have your projector yet do get it first and experiment!
Glenn Baumann is offline
post #5 of 6 Old 06-21-2013, 08:57 AM
Liked: 3616
Mike,
Joe
I would personally choose 120". At that size you will be able to use low lamp for a little while and then go to high lamp. Talking best image mode here. If you go with 130", then I think you will start off in high lamp best image mode and not have real long lamp life. To some people lamp life is just something they factor in as an expense for being able to go large. You just have to decide. Many people do find 130" a view-able size from 12/13'. You have to decide what is acceptable to you. Good suggestion of shinning on the wall and experimenting. Many people get their projector first, for this very reason.
post #6 of 6 Old 06-21-2013, 10:36 AM
blastermaster's Avatar
Quoted: 438 Post(s)
Liked: 555
Joe
First, I think you will be pretty surprised how awesome good 3D can be, so you MAY want to factor that in, as going with a slightly smaller size you will get a brighter, punchier picture. 130" will be plenty sharp. I have about that same size and I sit 12" away and it's razor sharp. I wouldn't sit any closer than 11" as that's where I can ever so slightly spot the weave on the XD in very bright scenes. I do have a bright projector relative to yours on paper (optoma hd3300), but if I'm not mistaken the reference setting on your PJ still puts out a lot of lumens. That said, I like a bright picture. The best advice given previously is to test those sizes on a wall and determine what looks best to your eyes. If your image is too close to the ceiling and you have a bright ceiling it will kill the contrast as well. Lots to consider.
blastermaster is offline
Reply Screens
