Best Ceiling Recessed Motorised Screen for Room with Light Walls, White Ceiling and Epson 5020/6020. - AVS Forum | Home Theater Discussions And Reviews
Old 06-23-2013, 01:16 PM - Thread Starter
AidenL's Avatar
Quoted: 471 Post(s)
Liked: 218
Hi all,
Hi from Ireland, and just to say, this is my first thread on here so hope you can help. I have been reading AVS for a while now and quite amazed by the depth of knowledge on here.
Ok, I'm hoping for some help - I'm about to buy and Epson 5020, or 8100 as its called over here.
I am attaching a few pictures of my room so you can see the conditions I'll be working with.
The room is light coloured as you can see, with a white ceiling and wooden floor. I can't change any of the decor.
I can get a ceiling recessed screen from Draper with the ReACT screen surface, and a 104" diagonal screen size - thats 2.4m wide, but I'd like to go for around a 120" diagonal screen size, all in 16:9.
Just wondering do you know if any manufacturer makes a screen that size, to those specifications, and also, any recommendations based on what I should use for my room.
Hope you can help and thanks in advance.
Display : JVC X7000 Projector | SE 103" Enlightor 4k | LG 65B6 OLED |
Sources : Oppo UDP 203 Multizone UHD Player | Apple TV3 | HTPC | Sky Q UHD Satellite | Sonos Connect | Synology 24Tb |
Audio : Marantz 8802A | Genelec 8050 LCR | Monitor Audio IDC Sides & Rears | Seaton Submersive Master/Slave |
Control : Control 4 |
AidenL is online now
Old 06-23-2013, 01:20 PM - Thread Starter
AidenL's Avatar
Quoted: 471 Post(s)
Liked: 218
http://www.avsforum.com/g/i/229837/beginning/sort/display_order/
http://www.avsforum.com/g/i/229838/beginning/sort/display_order/
