Acoustically Transparent Screen - AVS Forum | Home Theater Discussions And Reviews
Old 06-28-2013, 09:48 AM - Thread Starter
silicondt's Avatar
Hey all!
We are in the market for an acoustically transparent screen.
What are your guys thoughts on a good screen? Budget can go up to $3k for screen.
I have come to the conclusion that weave is better than perforated correct?
I called some companies up and was quoted a draper screen.
Draper Onyx Permanent Wall Screen, 65” x 116” Viewing Area w/ Clearsound Whitewave Acoustically Transparent Surface
Does anyone have any experience with this material or suggest something different?
Daniel
silicondt is offline
Old 06-28-2013, 10:20 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
One of the pro calibrators the frequents the forum did some testing on a bunch of screen materials a while back. First section is non AT second section (pate 6) is AT but the heading was copied and pasted without changing it to say AT
http://accucalhd.com/documents/accucal_front_projection_screen_report.pdf
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 06-28-2013, 11:26 AM - Thread Starter
silicondt's Avatar
I think I am going to end up getting Lunette AcousticPro 4K Elite Screen. 16:9
Can anyone tell me, on a curved screen. Do you need an anamorphic lens?
The projector I am getting is the DLAX55 JVC which says it has a pincushion adjustment for curved lens?
But does that still mean I need an anamorphic lens?
Daniel
Old 06-28-2013, 12:59 PM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
You use a curved screen to compensate for an A-lens. Not the other way around. If you are only going to do 16:9, there is no reason to do a curved screen let alone an anamorphic lens.
BllDo is offline
Old 06-28-2013, 01:15 PM - Thread Starter
silicondt's Avatar
We wouldn't be buying the curved screen to "fix" anything.
We would be buying it to have that wow factor of a curved screen.
The only thing I was curious about was the focus issues?
So a curved 16:9, how would you focus the center different from ends?
--Daniel
Old 06-28-2013, 03:16 PM
Mike Garrett's Avatar
Quoted: 5570 Post(s)
Liked: 3550
Daniel
You do not really need a curved screen since you are not using a lens. Also, You will not be using the pincushion adjustment. A curved screen with no lens will give you barrel distortion, not pincushion, so the adjustment would not help. Even if you were using an A-lens, I still would not recommend using the pincushion adjustment. If you would like to talk screens, give us a call.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 06-29-2013, 01:30 AM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
--Daniel
The OP wasn't talking about you using a curve screen to fix anything. A curve screen is used with an A-Lens or you will degrade your image. Also, I don't think you can even buy a 16:9 curve screen. A curve screen is for cinemascope screens, therefore an A-Lens is needed.
blee0120 is offline
Old 06-29-2013, 08:43 AM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
--Daniel
If you want wow factor, go with a cinemascope screen. Then you can use a curved screen and an a lens. That's wow.
BllDo is offline
