What are the highest gain AT screens available? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-30-2013, 07:16 PM - Thread Starter
mmiles's Avatar
Quoted: 465 Post(s)
Liked: 214
Looking for an AT screen with the highest gain possible.
Mike Miles
mmiles is offline
post #2 of 5 Old 06-30-2013, 09:26 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Search this forum but I think you will find 1 is about it
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 5 Old 07-01-2013, 08:57 AM - Thread Starter
mmiles's Avatar
Quoted: 465 Post(s)
Liked: 214
That's what I was thinking too. I thought someone had a 1.5 material but I guess I am wrong.
Mike Miles
mmiles is offline
post #4 of 5 Old 07-01-2013, 06:31 PM
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
The only Acoustically Transparent screens that come with a gain higher than 1.0 (Unity) gain are the PERFORATED type screens such as those from Stewart Filmscreen and others!
These type of screens can be had with gains upwards of 2.0 and maybe higher and they have round holes for the transmission of sound. Stewart perfs their various screen material types to order, they are of very high quality and they can be quite costly! eek.gif
The other type of acoustically transparent screens are the WEAVE type screens and these are as the name implies weaved and the sound passes through the little voids between the threads as opposed to the sound passing through the round holes of the vinyl perfed screens. The actual tested gain of the weave screens tops out at 1.0 or a bit less contrary to claims of 1.2 gain on some and some of the higher end finer weave type screens can also be quite costly! eek.gif
There are some that prefer Perf screens and some that are proponents of the Weave type screens for various reasons but I won't be getting into that debate here! wink.gif
Glenn Baumann is offline
post #5 of 5 Old 07-03-2013, 08:03 AM
BobL's Avatar
Liked: 56
You can get the Stewart 5D (2.0 gain) in microperf.  Probably the largest gain AT screen.
BobL is offline
Reply Screens
