Help with installing motorized projector screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-04-2013, 08:49 PM - Thread Starter
jutang's Avatar
Need input from the electrician gurus on this forum.
I bought a brand new Draper Screen Access E model off Ebay a week ago. Now that I'm going through the motions of installing the screen, I realized I may have not gotten all the parts! According to Draper's installation guide, I am suppose to connect 4 wires running from the motor to a control box and from there connect it to the wall switch. I have no control box or wall switch. Other than the obvious contact the seller and this is why you don't buy from Ebay comments is there a way I can go to a hardware store and buy the proper part(s) to complete my man cave?
Again I got 4 colored wires running from the motor. I have a family friend who works as a contractor, but has basic electrician knowledge and got stumped on this part of the install.
jutang is offline
post #2 of 2 Old 07-04-2013, 09:23 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
You should contact Draper and find out what is necessary and what is not. They should be able to supply the parts to you (or you can purchase from a dealer).
B.
Brian B is offline
Reply Screens
