Best fixed frame projector screen under $500 - 120" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-07-2013, 10:03 PM - Thread Starter
Project H's Avatar
Hi all,
I'm sure this has been asked before but I'm trying to get the latest opinion as I need to move fairly quickly on a screen for my HT set up. I have a Epson 8350 in a basement that has some ambient light that can be controlled with blinds with a throw distance of 13.5 - 14ft. I will be using this for movies, sporting events, gaming, and general shows.
I am looking for a 120" 16:9 fixed frame screen. Please let me know what gain, color - white/gray you all suggest based on the info provided above.
I've been looking at Visual Apex 1.1 found here:
http://www.visualapex.com/Projector-Screens/Projector_Screen_Details.asp?chPartNumber=VAPEX9120
Also, Elite Screens R120WH1 ezFrame Fixed Projection Screen ( 120-Inch 16:9 AR)(CineWhite):
http://www.amazon.com/Elite-Screens-R120WH1-Projection-120-Inch/dp/B000YUG02S
Another Elite - ER120WH1 Sable Fixed Frame Projection Screen (120 inch 16:9 AR)
http://www.amazon.com/Elite-Screens-ER110WH1-Projection-Screen/dp/B00366TZ3S/ref=sr_1_3?s=electronics&ie=UTF8&qid=1373255960&sr=1-3&keywords=elite+sable
What are you guys thoughts... I'd love to get some feedback. I dont want to go the Jamestown route due to the long wait time.
Project H is offline
post #2 of 9 Old 07-08-2013, 12:03 PM - Thread Starter
Project H's Avatar
I found this Monoprice screen for $477 - it's 120in 16:9, in HD Grey with .8 gain.
What do you guys think and does anyone recommend monoprice?
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10829&cs_id=1082914&p_id=7963&seq=1&format=2#description
I don't like the logo being there on center but can deal with it if this is truly the best option.
post #3 of 9 Old 07-09-2013, 02:49 AM - Thread Starter
Project H's Avatar
Here's another screen that I'm seriously thinking about purchasing. I'm local to the area and can purchase it for 360.
120in 16:9 Focupix high contrast grey screen with .9 gain found here:
http://www.htdepot.com/Focupix-Widescreen-Fixed-Frame-Screen-125-p/40027.htm
What do you guys think?
tsteele93 likes this.
post #4 of 9 Old 07-09-2013, 06:16 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Since you only criteria is price, a simple search of this forum using the words budget fixed frame will give you a bit more info to work with
http://www.avsforum.com/newsearch?advanced=1&action=disp&search=budget+fixed+frame&titleonly=0&byuser=&output=all&containingforum[]=23&replycompare=gt&numupdates=&sdate=0&newer=1&sort=relevance&order=descending&Search=SEARCH
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #5 of 9 Old 07-09-2013, 09:51 AM - Thread Starter
Project H's Avatar
The price is not my only requirement - I want the best performing screen that is suitable for the room that I had described within that budget
I'll check out that link. Anyone else able to let me know what they think of the Focupix Screen i high contrast grey with .9 gain?
post #6 of 9 Old 07-09-2013, 10:38 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Yes, of course you want the best screen for the money, my point was you were not looking for a certain screen fabric like AT or High gain.. Everyone who has asked that question want the best. As you go back though the pages of the search you will find lots of answers to your same question.
Doug
post #7 of 9 Old 07-10-2013, 10:12 PM - Thread Starter
Project H's Avatar
Another question.. Should I go with matte white 1.1 gain or high contrast grey .9 gain in a non dedicated home theater that may have some ambient light and white walls for now? I know grey has better black levels but white may be brighter
post #8 of 9 Old 07-11-2013, 05:07 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
You probably should contact the screen manufacture and request a sample pack of their available screen fabrics. This way you can hang them up in your environment (they are only about 1 foot square) to see if you get hot spotting, sparkleies, or visible texture. I have read more than a few unhappy posts over the years about budget screen texture, sparkles and hot spots. One fabric may be fine with one projector in one environment and completely awful with a different projector in a different environment. This goes for high end stuff as well, so it is always best to check samples first.
Good luck!
Doug
post #9 of 9 Old 05-12-2014, 10:55 PM
Chandr's Avatar
Hi Project H,
I'm also looking to buy a screen for under $600. What did you end up doing and do you have any suggestions?
Chandr
Chandr is offline
Reply Screens
Elite Screens Er120wh1 A1080p2 Sable Fixed Frame Projection Screen 120 Inch 16 9 Ar At
