Replacing screen material - AVS Forum | Home Theater Discussions And Reviews
Old 07-16-2013, 07:00 PM - Thread Starter
BHDavis's Avatar
I have a new JVC DLA-X35 projector that I'm using with my old Panoview Gray Fox II screen. As others have posted on these forums this combination makes for a slightly grainy image. The granular texture of the screen surface seems to give reflections from the very bright image sent by the X35.
I'm going to give Panoview (now Optoma I think) a call to ask about replacing the screen material. If they do this sort of thing is there a specific material I should request to go best with the X35?
This is an electric 100" diagonal 16:9 wall mounted screen. The projector is ceiling mounted at a distance of about 14' from the screen surface.
Thanks for any guidance.
BH
BHDavis is offline
