Question about my screen choice - AVS Forum | Home Theater Discussions And Reviews
Old 07-19-2013, 02:55 PM - Thread Starter
Gurt's Avatar
Quoted: 16 Post(s)
Hi guys,
I just received my BenqW1070 yesterday and installed it in my living room (bright room, white walls with blinds that can make it just a little darker during the day).
I am going to mainly use this projector for watching 2D and 3D movies as I have a 70" LCD TV mounted on the wall behind my projection screen.
I wasn't really sure which screen to buy, I knew that I needed a 100" diagonal and that I wanted a portable one as I did not want to install anything on the wall there. I ended up buying an Elite ezCinema screen which by the look and feel of it is quite "basic", or a little cheap.
The screen upon first pull-out had wrinkles (more like waves) from side to side. I called Elite and they told me that it's ok and that once I start watching movies, I won;t be able to notice it, which is semi-true, I did manage to see it when I watched scenes with horizontal camera pans.
It works well but I was wondering if there was any better option for me out there, a different brand that has better screens of the same kind.
I am attaching a few pics of my setup and the waves.
Thank you for your help!
Gurt.
photo.JPG 295k .JPG file
Projection screen 342k .JPG file
Screen waves 424k .JPG file
Gurt is offline
Old 07-19-2013, 05:48 PM - Thread Starter
Gurt's Avatar
Quoted: 16 Post(s)
Bump, anyone?
Gurt is offline
Old 07-19-2013, 06:09 PM
Crabalocker's Avatar
Quoted: 182 Post(s)
Liked: 122
I don't know anything about those type of screens. Do they make one that's tab tensioned? That would be my only recommendation....unless you went with an electric tab tensioned screen.
Good luck!
Crabalocker is offline
Old 07-19-2013, 08:39 PM
Threefiddie's Avatar
Quoted: 247 Post(s)
Liked: 121
you have to go Fixed frame or tab tension. if not it will always have waves.
** FOR SALE-Price reduced**Sony HW50ES + extra bulb + 5 pairs 3d glasses + Chief Mount **Click me**
Threefiddie is offline
